pharyngula Posted November 5, 2009 Share #1 Posted November 5, 2009 Advertisement (gone after registration) I've searched and read a lot of threads on the subject of Leica diopters but have not seen an answer to this particular question. The diopters seem to have a longer circumference (wider than current glass window on my M8.2)? I was wondering if someone could confirm this - if correct I assume a Leica diopter would not clear a standard Luigi half case? I'm near sighted in my right eye and far sighted in left. I can focus just fine with the left (except at close distances) but poorly with right. I wear Rodenstock progressives (just started wearing glasses this year) and can focus pretty well with them on but it is a struggle to see out to the 24mm framelines. Ideally, therefore, I'd prefer to focus through my right with both eyes open and see out to the edges (kind of why I like an RF to begin with) - hence, my interest in a diopter. BTW, my optician says my prescription is -1.25 in my right but I take it there is no -1.25 Leica diopter? Any recommendations (i.e., -1 vs. -1.5)? thanks Link to post Share on other sites More sharing options...
Advertisement Posted November 5, 2009 Posted November 5, 2009 Hi pharyngula, Take a look here Diopter for my M8.2 - will it clear Luigi case?. I'm sure you'll find what you were looking for!
Luke_Miller Posted November 6, 2009 Share #2 Posted November 6, 2009 I just got a +1.5 Leica Diopter for my M8.2. It is exactly the same diameter of the M8.2 eyepiece, so the eyepiece cutout of a halfcase will clear it nicely. I always get confused on which diopter is needed. Here is how I think it works. I need a +2 correction for my right eye. So I need to go up (or +) 2 from the Leica viewfinder, which is -0.5, thus a +1.5 diopter gives me a correction that is up 2. If you need a -1.25 correction it seems to me you would need to go down (or -) 1.25. That would require a -1.75 diopter. Since that does not seem to be a choice it looks like you must go with either -1.5 or -2 diopter. Link to post Share on other sites More sharing options...
pharyngula Posted November 6, 2009 Author Share #3 Posted November 6, 2009 I just got a +1.5 Leica Diopter for my M8.2. It is exactly the same diameter of the M8.2 eyepiece, so the eyepiece cutout of a halfcase will clear it nicely. I always get confused on which diopter is needed. Here is how I think it works. I need a +2 correction for my right eye. So I need to go up (or +) 2 from the Leica viewfinder, which is -0.5, thus a +1.5 diopter gives me a correction that is up 2. If you need a -1.25 correction it seems to me you would need to go down (or -) 1.25. That would require a -1.75 diopter. Since that does not seem to be a choice it looks like you must go with either -1.5 or -2 diopter. Thanks very much Luke - it is a relief to hear that the diopter is the same diameter as the eyepiece. I also heard back from my dealer in NY who tells me pretty much the same thing regarding the -0.5 of the viewfinder but he indicated I should go with a -1.0, which would give me a net -1.5 (as you point out, no quarter sizes). I agree, this can be a bit confusing to sort out. I'm going to see if I can live with shooting with my glasses for now but may order the diopter next week. Thanks again for the help Luke - appreciated! Doug Link to post Share on other sites More sharing options...
Big T Posted November 6, 2009 Share #4 Posted November 6, 2009 I just got a +1.5 Leica Diopter for my M8.2. It is exactly the same diameter of the M8.2 eyepiece, so the eyepiece cutout of a halfcase will clear it nice. Agree with Luke. I have the +1.5 Leica Diopter also and it is as Luke has said...... Very compact fit. I also use it on my 1.4x magnifier with the Summarit 90mm. Works a treat with this as well..... Link to post Share on other sites More sharing options...
Luke_Miller Posted November 6, 2009 Share #5 Posted November 6, 2009 I also heard back from my dealer in NY who tells me pretty much the same thing regarding the -0.5 of the viewfinder but he indicated I should go with a -1.0, which would give me a net -1.5 (as you point out, no quarter sizes). I agree, this can be a bit confusing to sort out. Doug If I understand this diopter stuff correctly (and I may not) a -1.0 diopter eyepiece is a difference of -0.5 from the Leica viewfinder (which itself is at -0.5). You need a correction of -1.25 to see clearly. A -1.5 eypiece gives you a correction of -1 and a -2 eyepiece gives a correction of -1.5. If your dealer will allow an exchange the best way IMO is to try several and pick the one that works best for you. Link to post Share on other sites More sharing options...
