Showing results for tags 's-e'.
Found 1 result
  1. After many years with Canon 5Ds I made the move to Leica M (240) in December 2016. I’ve chopped and changed the kit around so now I have : Leica M10 with 21mm/35mm f1.2 Voigtlander/50mm Summilux, 50mm collapsible Elmar (1954),90mm and 135mm - all Leica unless specified Leica Q my favourite camera EVER! Leica S-E (typ 006) with a 70mm f2.5, 120mm macro Ive even got and use a Sofort and a 1958 M3 single stroke ( used mainly with the Elmar) I’ve also had and sold a Monochrom ( CCD Sensor - imho the best rendering) I bought the S-E for studio work which due to illness I may not be able to do or at least very little. I am considering using the S-E as a part exchange on a Leica SL and either a 24mm-90mm or a 75mm lens ( preferable ) and the M to SL converter. after a long preamble my question is if I was to trade for an SL should it be for the Mark I or the SL2. Obviously I may need to add cash but your thoughts would be helpful. I shoot 90% Portraits of which 80% are in the outside world almost street ( hence 75mm lens ). The other 10% is my abstract art and I would use whatever I need ( Start with Q and M3 ) thank you in advance
