Showing results for tags 'o serie'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. Hi Everyone I have a query about the aperture settings on the modern 'O' Serie replica camera produced by Leica. I've considered putting a VOOLA aperture control ring on the front of the camera with a FISON hood, or possibly a suitable push on filter, when out and about, to allow easier adjustment of the aperture lever on the front of the lens. I know this works as I have transferred the VOOLA + FISON from my 3,5 Elmar to test. Using some sort of aperture control on the 'O' Serie is useful as otherwise the aperture lever is quite tricky to adjust as it is nearly flush with the front face of the lens. I've no doubt that even with a coated lens, the camera might benefit from the use of a lens hood (as do most cameras). The 'O' Serie lens is not detachable and has 1917 aperture values (f3,8; f4,5; f6,3; f9 and f12) and shutter speeds are 1/500; 1/200; 1/100;1/50; and 1/20s + B). The question is if instead of a VOOLA I tried a VALOO adapter, which has a similar connection to the lever on the 'O' Serie lens as the VOOLA but adjusts by aligning marks on the front of the adapter which correspond with modern aperture values, is the computation of the 1917 'O' Serie lens close enough to a 3,5 Elmar that if for instance f5,6 was selected on the VALOO, it would position the selector on the 'O' Serie lens to about the right place to correspond with f5,6 on the 'O' Serie and so on through the aperture range ? In other words would the use of a VALOO allow the use of modern aperture settings on the replica 1917 lens ? Any comments would be appreciated !! Thanks in advance, Robert
