Showing results for tags 'moving subject'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. I am curious to learn if anyone else is having problems with the Leica SL when shooting moving subjects. When shooting a moving subject, like a dog coming towards the camera, the Focus Point (green rectangle in viewfinder) jumps around and does not stick to the subject - it is almost like the Focus Mode is set to “Face Detection” (which it is not). If I continue to hold the shutter release half way down, & slightly recompose the image, the Focus Point tries to stay on the spot that it originally focused upon. Is there a way to set up the Auto Focus so that the Focus Frame/Point stays on the selected moving subject, rather than it jumping around the frame sporadically? Here are the camera settings I started with, though I have experimented with changing all of them. The problem is not quite as bad using the Single Focus Mode rather than the Continuous Mode. Focus Mode: Auto Focus Continuous (or Single Focus) Drive Mode: Continuous Medium Auto Focus Field Size: “Field” (or single point or zone) Auto Focus Mode: Dynamic (Tracking) Thanks, Mark Weidman
