Showing results for tags 'd lux 7'.
Found 8 results
  1. hello, I’m new here Can someone help ? When I try an open ‘ photo style’ in the menu of my D Lux 7, it say ‘this menu can’t be set’. can anyone tell me what I’m doing wrong ? thanks !
  2. Seasons Greetings! Do someone know more about the D-lux 7 flash usage? The flash in little size that comes with the package, use the camera's battery, does it mean although tiny but should still be quite "powerful"? Even close to the SF20 (or the SF24)? (Looks like it consumes a lot of power from the D Lux 7 batter in just few pop flash testing...) I think the main usage I would set for could be for fill-flash, reduced around 2 stops in setting...
  3. Greetings! May I ask questions about the new "D-Lux 7"... 1. It looks like the box comes without a square shape separate battery charger like the one on the "D-Lux 109", is it that correct or I am missing a charger in the package? 2. The D-Lux 7 package does come with a "AC Adapter" with a "Micro-B USB Cable" is it the only "charger" provided with the package (Please see attached photo here) ?? Is it the ONLY method to change the battery now?? 3. Is it possible to get a traditional charger like the one came with the "D-Lux 109" to charge the batteries? So that it does not need to connect the camera together each time need to charge, and can use the separate wall-plugin charger to charge extra batteries like for the "D-Lux 109" ? 4. Which method is a better one in your experience or reasoning? Thanks for your info 🙏
  4. Could someone explain why on the D-Lux 7 settings, the Fn9, Fn10 are "Off", could not be set?
  5. What are the Image Specs (RAW & Jpeg) with the 1:1 Format on the D-Lux 7? Anyone?
  6. I am greatly enjoying my D Lux 7 - terrific little camera. If you take a look at the attached image, taken only as a test, you'll see a foggy effect between the two trees. The sky was cloudy, but bright, and the sun was somewhere over the house, behind one of the trees. I was using a lens hood and I'm not certain if this is due either to incorrect exposure by me/ lens flare/ a fault. It is very reminiscent of the halation effect loved by some cinematographers. How are you all exposing in high contrast situations like this?
  7. Street Singer, Leicester Square, London
  8. Hi everyone. I've had a d lux7 for about two years, now I'm having problems with the physical buttons to the right of the display. Especially after turning the camera on, for some time if I try to scroll the images or use the physical buttons, the camera behaves badly (for example, one press of the button produces three or more movements scrolls, so the camera becomes unmanageable). Has this happened also to someone else? Let me say that the camera has never fallen to the ground. Thanks for the attention..!!!
