Showing results for tags 'flash sync'.
Seasons Greetings! Do someone know more about the D-lux 7 flash usage? The flash in little size that comes with the package, use the camera's battery, does it mean although tiny but should still be quite "powerful"? Even close to the SF20 (or the SF24)? (Looks like it consumes a lot of power from the D Lux 7 batter in just few pop flash testing...) I think the main usage I would set for could be for fill-flash, reduced around 2 stops in setting...
Anybody ran into the issue the flash on the Leica M10 does not sync at 180 and only at 125 or longer? I get a black band in the top of the image at 180 both in "start of exposure" and in "end of exposure" setting? So does this mean the actual shutter speed exceeds 180 or is the rear or front shutter to fast i.e. slow? Before bringing my camera in to Leica maybe someone can clarify the issue? Thanks, Ben
Hello all, I recently purchased the Leica multifunctional handgrip 14495 for my M246 camera and while trying to use the flash sync port with my Speedotron pack it didn’t work at all. I had my camera speed dial set to 180th of second as recommended for flash photography but the handgrip did not trigger the pack. Any suggestions on how to remedy the issue would be greatly appreciated.
- 3 replies
- m246 multi handgrip
- flash sync
(and 2 more)
Tagged with:
