Showing results for tags 'cl flash'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. I have a Leica SL and CL and use the CL generally as a light weight back up. The SL works very well with a Nikon compatible Profoto Air TTL trigger but when I put the trigger on the CL, which seems to have exactly the same pin configuration, the flash will not fire. The link between trigger and flash works fine; it's the connectivity between the CL and the trigger that seems to be the problem. Any ideas or suggestions welcome. Thanks David
