Showing results for tags 'apo summicron 50mm'.
Found 2 results
  1. Because Voigtlander has released the VM Apo Lanthar 50 mm I thought you might be interested to see a comparison of the Apo Summicron and the Apo Lanthar. I have tested with the Sony A7R4. If you see the pictures you can hardly tell them apart. The Apo Lantar is a gem for its money. Contrast and sharpness of both lenses are full open already impressive. The Leica has the advantage that it has the same quality and is even smaller then the Lanthar For all pictures see
  2. I was in Harve de Grace this past Sunday. Using my M10-P with APO Summicron 50mm lens, I capture images of passing boats in the river. When processing the selected image in Capture One Pro, I made a tight crop for the best composition of this image. I was amazed at the sharpness, contrast, detail and resolution that the APO Summicron 50 is capable of with this image. ISO was set to 200 and was shot handheld. Attached is the full image and my final, cropped, version. Just image what this lens will be able to do with a higher pixel sensor. Unfortunately, due to the image size limit on this forum, the images appear to be grainy or noisy. This is not the case with the full size JPGs output from Capture One Pro. They look great with no grain or noise and lots of details retained. Regards, Bud James Please check out my fine art and travel photography at www.budjames.photography or on Instagram at www.instagram.com/budjamesphoto.
