Showing results for tags 'M39'.
I've used my Visoflex 1 on my '37 Leica II, fitted with bellows, to take macro shots but I've just put it on my IIIf along with a 200mm Telyt lens to check it over before I take it out for some alpine photography in a few weeks time. The problem is that although I can swing the camera through 90 degrees for portrait and landscape views, the camera is not horizontal or vertical, but off by a few degrees. This means that I can't get horizontal at all (unless I unscrew the Visoflex slightly), and I can achieve vertical but only by moving the camera off one of the Visoflex end-stops (I hope that makes some sense?!). Can I adjust the 'end stops' on the Visoflex so that I can ensure horizontal / vertical setting of the camera? If so, how? Thanks, David.
Hi, I'm new to the forum. I just bought a grouping of vintage Leica screw mount cameras. I'm having trouble identifying this one. The serial number says it's a Leica I, but it looks like a II. I'd love to have thoughts on this camera from the members. John
