lct Posted April 26, 2007 Share #1 Posted April 26, 2007 Advertisement (gone after registration) Want to put a red nose on your dear old 'cron 40/2? No problem, you just need: - a 39mm UV-IR Leica filter (#13410) - a Leica hood #12518 dedicated to the 'cron 40/2 - a 37mm rubber ring - a pin and a die grinder 1. Grind the filter housing of the hood in order to enlarge its inner diameter to 37mm: http://tinyurl.com/rv7w/DSC00720_afterweb.jpg 2. Remove the blocking ring of the filter with a pin or same: http://tinyurl.com/rv7w/DSC00710_afterweb.jpg 3. Insert the glass into the filter housing: http://tinyurl.com/rv7w/DSC00721-afterweb.jpg 4. Insert the rubber ring over the glass: http://tinyurl.com/rv7w/DSC00731-afterweb.jpg 5. Screw-in the hood: http://tinyurl.com/rv7w/DSC00728-afterweb.jpg Now enjoy flare, ghost images and genuinly black blacks at last... ... I mean with the M8 of course Link to post Share on other sites More sharing options...
Advertisement Posted April 26, 2007 Posted April 26, 2007 Hi lct, Take a look here Leica IR filter for Summicron-C 40/2. I'm sure you'll find what you were looking for!
