M240 and old lenses
Last Saturday I already try R lenses.
Just to extend my thoughs and the versatility of the M 240 I played yesterday with some adaptors and lenses combinations
with Viso III and ZOOAN + Tele Elmarit 2.8/135 head, with the mirror set in up position the liveview is activated.
with a 42 mm long tube + Telyt 4/200
and with a 42 mm long tube + Telyt 5/400
x
Some picts with this combos + 1 with R-M adapter and Apo 180
Hello Jean Claude,
Nice photos.
Wouldn't it be easier to focus wide open & then stop down like with a pre-set lens?
Do you do it the way you do because there is a degree of focal shift with the 180mm Apo?
Best Regards,
Michael
Thanks Michael
The liveview and the viewfinder works the same from wide open to narow one.
The processor is able to correct in relation to
it is not esay to stabilise the set if you use the focus peak.
Thanks - which adaptor were you using? I'm so frustrated that the Leica R to M isn't available!
Chris, I have Novoflex R to M and Oly OM to M adapters. Will they not work? Are they unavailable? They work on the M9, and they're built very well!
