Part Number 22228/500934 problem with R ROM lenses
algrove
Recently acquired this 22228 R to M Adapter. Started seeing how various R lenses I have recently also acquired work on my Ricoh GXR with A12 mount with focus peaking.
All non-ROM lenses mount on the 22228 and focus perfectly. BUT, any ROM R lenses I try to mount, on this admittedly "early" adapter, will not mount since the ROM contacts get in the way of the bayonet mount, i.e., the lens will not even begin to turn because it will not seat in place.
I played with the new M adapter for R to M lenses at Photokina, but not really having any experience with R lenses at that time, I did not look to see which type of R lenses they were using on the new M-240 Adapter-3 cam or ROM.
Anyone have any insights if ROM lenses will work in the future or should they be de-ROMed?
I know this all sounds a bit stupid, but the ROM strip seems to be the culprit and prevents me from mounting any ROM lens on this pre-ROM adapter.
If anyone is using a ROM lens with an adapter that currently works on an M camera or an M mount on any camera, kindly give me some insight. Maybe there are new non-Leica adapters that are currently working fine with ROM lenses. Thanks.
My 222228 behaves the same. I guess the Novoflex adapter and certainly the new R adapter is unproblematic.
Jaap- Do you have a Novoflex adapter that works with your ROM R lenses or are you in a waiting mode for the new Leica adapter?
If I may butt in.
I have both the 22228/500934 R to M as well as the NOVOFLEX LEM/LER Adapter.
My APO-Telyt-R 1:4/280 doesn't fit onto the 22228/500934 R to M Adapter.
But it fits onto the NOVOFLEX LEM/LER Adapter.
In contrast my APO-Telyt-R 1:3.4/180 fits on both Adapters.
I also noticed that the male/camera end of the 22228/500934 R to M Adapter looks quite different from the corresponding end of the NOVOFLEX LEM/LER Adapter.
The former fits onto my Visoflex III, but doesn't fit onto my M9.
The latter seems to have a regular M-bayonet and fits onto my M9.
So what use does the 22228/500934 R to M Adapter have for the M-240?
I also noticed that the red plastic lever easily comes/breaks off from the 22228/500934 R to M Adapter.
Can that plastic lever be replaced with a more robust metal one? Could DAG help with that?
@wildlight--If by "R only lenses" you mean 3 Cam, then my 22228 works with those R only lenses, just not with ROM R lenses similar to what K-H describes.
@K-H--Does your 280/4 have ROM? Mine does so I am looking for something before next year to adapt it to my digital M cameras.
"What was the originally intended use of the 22228 Adapter?"
IIRC it was to use Leicaflex lenses on the Leicina movie camera.
3-cam lenses are not R-only. R-only lenses are either 3rd-cam (also called R-cam) or ROM.
Hello K-H,
The 22228 was an adapter which allowed circa 1970's Leicina movie cameras, which used an "M" mount but otherwise had their own lenses, to use Leicaflex lenses as well. There were also adapters to use Minolta lenses, "C" mount lenses & adapters to use other lenses on the Leicina as well.
Best Regards,
Michael
My 280/4 is from 1993 and was advertised as: "LEICA R 280mm f4 APO TELYT R CAM BOXED".
I don't see a ROM.
Thanks. Guess I need to get the Novoflex adapter after all.
Well, that depends. You could also wait for the new Leica Adapter or get an inexpensive one from Fotodiox:
Amazon.com: Fotodiox Lens Mount Adapter, Leica R Lens to Leica M Adapter, fits Leica M-Monochrome, M8.2, M9, M9-P, M10 and Ricoh GXR mount A12: Camera & Photo
The reason I finally needed precision made NOVOFLEX adapters is given here:
http://www.l-camera-forum.com/leica-forum/digital-forum/256040-focus-apo-telyt-r-280-4-a.html
Indeed, both NOVOFLEX Adapters, the NEX/LEM and the LEM/LER are so well made that I can focus the 280/4 lens with a NEX camera, swap adapter and camera, and shoot with an M9, lens still in focus. :D
