Walterrxeyepice on M9
gpwhite
Does anyone have experience with the Walterrxeyepiece that is now advertised on the forum host site?
I have used -1 and -1.5 diopters since M6 days and never found them to be very satisfactory. I would love to be able see the imagery in the natural M9 viewfinder in its full brightness and clarity.
I do not have much of an astigmatism, but I am wondering if a larger diameter corrective lens would make the screw-in correction for the viewfinder less destructive in terms of brightness and field of view (i.e., frameline visibility)?
thx, Peter
  • Replies 86
  • Created
  • Last Reply
Well, a screw- in diopter does not make much of a difference to brightness and FOV, as opposed to a magnifier, so it may be you are confusing the two. In my experience the only time a diopter makes an impact is when it is not completely clean when mounting.
Any advantage thisone would have in size, however, would be offset by the greater distance between ocular and diopter.
Anyway, this makes a Leica diopter look like an absolute bargain.
I too would like to know if anybody has taken a 500 $ gamble.
Jaap, thanks for your comments. When I screw in my Leica diopters (not the magnifiers that I also have and can use in tandem with the diopters), I find that the visibility of the viewfinder is constrained and less bright. Furthermore, I cannot see the widest frameline set when I foveate on the focusing patch.Thus, I find that the diopters are useful, but at a clear cost in quality to what I can see in the viewfinder.
I agree $500 sounds more like an S2 attachment than a plebian-line M series accessory, but I imagine volume for these pieces might be even smaller than the S2 lenses!!
Ah yes, those Leica R series viewfinders were utterly fantastic, so I imagine an S2 is like viewing an IMax movie.
Hi,
I have a pretty bad astigmatism and have one of the eyepieces on order so when I have it in a few weeks time I will report back and let you know. I'm hoping it's going to make a difference especially as I have just got my new Noctilux and need all the help I can get with the focus!!
Cheers
Mark
We'll be doing a full review of the Walter RX Eyepiece over on La Vida Leica very soon; we have one enroute!
Being that I wear eyeglasses (though not to shoot) and have mild astigmatism, this should be a great option over regular diopter lenses!
will you let us know when it's up, please?
Absolutely. They're making the eyepiece now to my prescription which I had sent them.
This appears to be an ingenious solution.
How did you specify the usage to your optometrist? That is, did you specify a working distance, as you would for reading glasses? And if so, what was that distance?
Harry
Harry
I merely provided my prescription to them and they'll make up the optical piece to match (which can also by done by your own optometrist should your prescription change - as they often do).
For example, my prescription is (with RIGHT capitalized as it's my shooting eye):
                SPH        CYL        AXIS
DISTANCE:
RIGHT         +1.50      -0.50       005
Left          +1.50      -0.50       175
READING:
RIGHT         +1.00
Left          +1.00
  • 3 weeks later...
thx, Peter
Hi Peter,
I have just received my Walter RX eyepiece, and I am very happy with the results. My glasses have always been my biggest impediment when using a Leica. It is though I have been given a new lease on my photographic life. In fact, the eyepiece works really well in that the focus is actually spot on. I use multifocals and they are not always 100% in focus with what I am looking at through the cameras eyepiece. My glasses must be perfectly lined up to the camera to be in focus. The eyepiece is however, perfectly in line with my astigmatic bad spot. I recommend it highly.
Kind regards
Leslie Jacobs
Hi Peter,
Kind regards
Leslie Jacobs
Hi Leslie,
Would you care to quote the extent of your astigmatism? And, how about shifting between vertical and horizontal; does the lens rotate smoothly and quickly?
Harry
My main concern is that I don't always keep my head level when taking a photo. How would that work in practice? The best solution of course it to have the lens fixed to your eye/head (like in spectacles or in eye lenses). Still a bit hesitant but it really would solve a big issue for me not being able to always clearly see through the viewfinder.
The eyepiece rotates by itself (think self-leveling). Pretty ingenious.
Still waiting to receive mine... Should be any day (it's in transit).
Three pints and all is well...
Hi Leslie,
Harry
Hi Harry,
I will post the numbers tomorrow. The lens is mounted on a roller bearing and has an offset weight that reacts to gravity. It is smooth and immediate.
Les
