chris_tribble Posted January 28, 2010 Share #1 Posted January 28, 2010 Advertisement (gone after registration) Joshua - a list member, raised this with me. In LR2.6 the EXIF for a manualy selected 135 APO Telyt comes up as the Elmarit M 135 2.8 - Odd as I don't think this happened in LR 3 beta. Not sure if this is a firmware or software issue. Do others have similar experience? Screen shot from LR 2.6 below. Best C: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/110937-odd-exif-issue-with-135-apo-telyt/?do=findComment&comment=1203980'>More sharing options...
Advertisement Posted January 28, 2010 Posted January 28, 2010 Hi chris_tribble, Take a look here Odd EXIF issue with 135 Apo Telyt. I'm sure you'll find what you were looking for!
scott kirkpatrick Posted January 28, 2010 Share #2 Posted January 28, 2010 Joshua - a list member, raised this with me. In LR2.6 the EXIF for a manualy selected 135 APO Telyt comes up as the Elmarit M 135 2.8 - Odd as I don't think this happened in LR 3 beta. Not sure if this is a firmware or software issue. Do others have similar experience? Screen shot from LR 2.6 below. Best C: To see if it is firmware, just put the chip back in your M9 and check the info screen. (After setting this manually, of course if you take a fresh shot.). I'd bet there is a software table somewhere in LR that hasn't gotten the manually available values filled in yet (or not until 3.0). This raises a question to Carl and Sandy, or resident EXIF/MakerNotes decoders -- how does the M9 tell the DNG file that a manual table entry was set? In the past (M8) the 8 bits of frame lever position and 6bit code were passed in the MakerNotes. What's happening with that info this time? scott Link to post Share on other sites More sharing options...
UliWer Posted January 28, 2010 Share #3 Posted January 28, 2010 Well, you have to read the message given in the EXIF. It says: "Why did you take me, one of the best Leica lenses ever made, to take a photo of your microwave??? My poor cousin, the old Elmarit, could do this for you." Link to post Share on other sites More sharing options...
Alnitak Posted January 28, 2010 Share #4 Posted January 28, 2010 Well, you have to read the message given in the EXIF. It says: "Why did you take me, one of the best Leica lenses ever made, to take a photo of your microwave??? My poor cousin, the old Elmarit, could do this for you." ROFL! Link to post Share on other sites More sharing options...
sandymc Posted January 29, 2010 Share #5 Posted January 29, 2010 So far as I am aware, there is only one code in Leica lens code table for a 135mm lens, which is code 9, and is associated with the description "Elmarit-M 135mm f/2.8 (I/II)". Accordingly, that is what both LR and CornerFix will show for a code 9 lens. If there is a different code for an Apo Telyt, pass it along to me, I'll update CornerFix, and no doubt LR will also be updated. Sandy Link to post Share on other sites More sharing options...
AGeoJO Posted January 29, 2010 Share #6 Posted January 29, 2010 Sandy, Indeed, LR recognizes the 135mm APO-Telyt as code 9, "Elmarit M 135mm f/2.8 (I/II)". However, this lens is listed as one of the lenses that can be set manually on the M9 and identified properly as APO-Telyt. It is not a big deal, I was just curious whether my case was isolated, which apparently is not as Chris confirmed his to do the exact same thing. Thank you very much, Joshua Link to post Share on other sites More sharing options...
sandymc Posted January 29, 2010 Share #7 Posted January 29, 2010 Advertisement (gone after registration) That's correct - the M9 has menu selections for the two lenses separately, but both menu selections result in the same code being written to the files's MakerNotes. Hence what LR or CornerFix read. Sandy Link to post Share on other sites More sharing options...
Ario Arioldi Posted January 29, 2010 Share #8 Posted January 29, 2010 Also in the attached page, generated by Exif-tool, there is only code 9 available to identify a 135mm lens, i.e, Elmarit M 135. Panasonic Tags. Cheers, Ario Link to post Share on other sites More sharing options...
AGeoJO Posted January 29, 2010 Share #9 Posted January 29, 2010 Sandy, thank you very much for the explanation. Now, I know the reason for that. Joshua Link to post Share on other sites More sharing options...
scott kirkpatrick Posted January 29, 2010 Share #10 Posted January 29, 2010 That's correct - the M9 has menu selections for the two lenses separately, but both menu selections result in the same code being written to the files's MakerNotes. Hence what LR or CornerFix read. Sandy Sandy, the first interesting question is what codes does the M9 put into the EXIF in the usual 6-bit position when you enter a specification for an uncoded lens? Do they default to the newest model of the same focal length, or are there variations intended to call up an appropriate vignetting correction? If the latter is true, we should have some new information for Carsten's table. Second, when manual table entry is used, isn't there some information about it in the now voluminous Maker Notes, supplementing the EXIF? Do you want some help or samples to look for it? scott Link to post Share on other sites More sharing options...
sandymc Posted January 29, 2010 Share #11 Posted January 29, 2010 Sandy, the first interesting question is what codes does the M9 put into the EXIF in the usual 6-bit position when you enter a specification for an uncoded lens? Do they default to the newest model of the same focal length, or are there variations intended to call up an appropriate vignetting correction? If the latter is true, we should have some new information for Carsten's table. Second, when manual table entry is used, isn't there some information about it in the now voluminous Maker Notes, supplementing the EXIF? Do you want some help or samples to look for it? scott Scott, The code appears to be exactly the same code as a coded lens on an M8 would produce. As regards the new MakerNotes and whether the actual menu selection rather than just a lens code might be in it, that question would have to go to Carl. I only looked into them enough to get the basic information that's interesting from a CornerFix perspective. Regards, Sandy Link to post Share on other sites More sharing options...
chris_tribble Posted January 31, 2010 Author Share #12 Posted January 31, 2010 Sandy - thanks for the clarification. I'm writing to Leica to ask if it's possible for this to be corrected - it's a bit silly if manual selection brings up the wrong Exif. Best... Link to post Share on other sites More sharing options...
