IR Filter for Summarit Query
TimF
No, not that one! ;)
I just bought an old L39 50mm f/1.5 Summarit, which I'd like to use on my M8.
This has an E41 filter thread, which size isn't available in the B+W range. So, the question is, would their 40.5mm filter fit OK, or do I need to go up to the 43mm one and get a stepping ring?
TIA :)
TIA :)
The 40.5 filter doesn't fit the Summarit or the Xenon. I even tried removing the 40.5 glass from a filter and put it in to a 41mm empty filter frame. That doesn't work either. I ended up using a 41 to 46 step up ring and a 46mm UV/IR filter. It works fine. I also bought a generic 46mm lens cap to keep the dust out.
Fortunately I have two lenses that take a 40.5mm filter so I didn't lose anything.
Len
Len
If you remove the filter glass from an original Summarit filter (banjonet) the 40.5 will screw into there.
The size IS available. I bought a B&W 41 last year at Foto Huppert. It is a special order and takes about two to three weeks.
I bought a 41mm B+W UV Haze filter last year but did not see the UV/IR in their catalog. I really would like to have the right filter. While it works I really don't like the step up ring approach. Thanks for the info.
Len
Jaap - many thanks for that. I shall consult my dealer soonest. :)
Cheers to all.
Just in case anybody doubts: E41, Thread size M41x0.5
i also have a 41mm b&w uv/ir cut filter from foto huppert - no problem except it seems to be standard in black. here are the latest uv/ir cut sizes:
WÄHLEN SIE HIER IHRE GEWÜNSCHTE FILTERGRÖSSE AUS -
- 19,0 mm
- 24,0 mm
- 25,5 mm
- 27,0 mm
- 28,0 mm
- 28,5 mm
- 30,0 mm
- 30,5 mm
- 34,0 mm
- 35,0 mm
- 35,5 mm
- 37,0 mm
- 37,5 mm
- 38,0 mm
- 39,0 mm
- 40,0 mm
- 40,5 mm
- 41,0 mm
- 43,0 mm
- 46,0 mm
- 48,0 mm
- 49,0 mm
- 52,0 mm
- 55,0 mm
- 58,0 mm
- 60,0 mm
- 62,0 mm
- 67,0 mm
- 72,0 mm
- 77,0 mm
- Bajonett
- Filterglas
- Serie
while i'm at it, i didn't want to wait for the original lens hood (can be quite expensive), so i ordered a voigtlander lens shade from cameraquest. $30 for the lens shade, or $50 with cap. here's the article:
41 Screw in metal Hood, black or chrome, fits among others Leica 50/1.5 Summarit, 35/1.4 Summilux non Aspheric, 60/3.5 Visoflex Elmar, optional push on Voigtlander cap.
good luck with your summarit 1.5. post some photos later?
greetings from hamburg
rick
