Nasty Green Streak Again!
WmAl
M8 & 35mm Summilux
This hasn't happen since FW1.201. I don't think the bright light theory is correct because all scenes before and after are in same lighting scenario. Heavy overcast for entire trip.
Has this occurred to anyone else with FW 2.0? Shot over 4000 photos. :eek:
No that's the same as before. Bright light right at the edge of the frame on the short sides of the sensor.
If you had raised or lowered the camera/sensor just a bit this wouldn't happen.
And I think it happens when the light at the edge is much brighter then the rest of the scene. Not just a Bright/Bright/Bright light.
Shootist: Is this more likely to happen when shooting in vertical framing? Then why isn't there more flare at same time? How about a longer lens hood?
Thanks to everyone for your help!
:confused::eek:
The green streak is believed to occur when light gets under the black mask right at the edge of the Kodak CCD and messes up the zero level for that horizontal row. It only affects one side of the frame because the two sides are read out independently. Leica has said that it can't be fixed with only firmware, which means it isn't going to go away until there is a newer CCD chip.
I have one sample (in about 15000 exposures), but I didn't go looking for it. However, this example is a little unusual in that it is weakest at the edges and strongest in the center just before it stops. Perhaps that is because the light at the edge is very strong but not point-like.
scott
Maybe, but it doesn't appear to be a common problem. I've had it happen on 2 out of over 16,000 frames - and those two were on consecutive frames of the same subject.
Confirm... I succeded time ago in obtaining it, after some trials at home with a lamp at border-frame... few centimeters of displacement were sufficient to have or not to have this green band.
