Strange Streak - dead pixels or else?
Venkman
Hi,
today I wanted to determine whether I need to clean my sensor soon or not - so I took a shot at my video screen and noticed a band in the upper left corner. My initial reaction from looking at that band was "Oh no, dead pixels" - but then I took a couple of shots and found that it does not show while shooting wide open?
So, what's the expertise of fellow forum users on this one?
(apart from "yes, the sensor should be cleaned")
All 100% crops of the upper left corner.
Please discuss - Dirk
You have dust on your sensor and you can clean it with Eclipse and their swabs. If this is your entire sensor, two dust spots is not bad and may not be worth the effort. The streak, I believe, is a known firmware bug at high ISO that is supposed to be fixed in 1.10. Someone correct me if I am wrong.:)
Hehehe - exactly what I feared, two answers, two opinions.
As for dead pixels - why would they show only on apertures above 11? Dead is dead I would think?
As for the bug - in the whole shot at 2500 I saw the "white" band just right off the center - but this is in the upper left corner?
The more I think about it, the more confused I get.
Well I don't think they are 100% dead, let's say they are in a really bad shape:)
BTW, do you mean that you don't see tham at F2.8 and ISO 2500?
Nope - that's exactly my point.:confused:
Jaap, I would be happy if that is dirt. But it's almost too regular for something natural :)
Make your test just with shutter speeds under 1/30 or lower with the different iso settings.
I think you will see the dead pixel row (if it is the whole row) between iso 640 and 2500.
This means, for me, you should change the sensor or the whole M8.
Good luck.
(I ' waiting for my second M8)
Mario
See also "M8 and stripes but not the Banding problem!"
You're right. I did test with 1/15 at 2.8 and it shows as well.
It's just that small line, maybe 1/5 of the total height, but it shows.
Contacted Leica already, let's see what they say.
Thanks all for your advice - Dirk
  • 3 weeks later...
  • 2 weeks later...
I recently had a similar problem--but my "line" ran from top to bottom, and was always lighter than surrounding pixels (and thus pretty much only visible in darker areas of the image). Like yours, it became more pronounced with higher ISOs, but unlike yours, it was aperture independent and showed clearly wide open. I also understood at that time (from another forum member) that lines of pixels fail in rows, not columns.
Walt
