Summarit 75, a little problem
luigi bertolotti
Summarit 75 is the first new lens I bought for my M8, 3 years ago, and by far the tele I've used most: in these days I noticed that a very little play is showing, between the lens group and the focusing barrel: little, indeed, but when lens is extended, one undoubtly feels it, even if not when you operate the lens in normal usage (and IQ is completely un-impacted, at the moment) : has someone else observed this ?
I'm a little annoyed... I have >50 years old lenses with complex and heavy construction (Summarex 85, Telyt 200...) that are still solid as rocks... the only play I am accustomed is the typical f stop ring "a bit over wide open and full closed" which hasn't any impact, but a lens assembly that, potentially, goes a bit decentered/tilted is a thing I don't like...
luigi,
sorry to hear that. i have the same lens for about a year and have not noticed that kind of problem. actually it feels incredibly well built, considerably better than my second-hand 35mm summicron (built somewhere around 2005). on the summarit f-stop is precise and does not have any play at all. focusing is smooth, resistance perfectly uniform across the entire focusing range.
i'd guess this is something CS should take care of ...
markus
Please correct me, if I am wrong, but there seems to be a slight play in several Leica lenses focus assembly, which - according to CLA history - is negated by the type and condition of grease in the focus assembly.
I have a second hand 50 Lux ASPH and 35 Cron ASPH and both have the slight play, one can feel with the fingers touching both assembly groups and slightly moving the front group.
I have seen no impact on image sharpness or function so far. I forgot somewhen about it and plan to ship them for CLA later.
Sorry to say they don`t make `em like they used to.
Craftsmanship in the 50 `s and 60`s was superb. Today it what they can get away with.
But I must say it was 50% better than Japanese decades ago, today it is 1000% better.
The new Nikon glass has a lot of plastic in it and it gets worse all the time.
Construction robustness was one of the things they gave up to make the cheaper Summarit line.
The other side of the coin is the the optics are better now if you consider high resolution the judging criteria.
Ok, I'm rather relieved...for the moment I do nothing... I hope it doesn't become more significant... lens is still perfect as IQ: yesterday I checked some other lenses of mine... I notice a similar play in my very old Summilux 35 of 1960... "tube" lenses like Elmars 90 and 135s are still perfect (with variations in focusing smoothness, but no "axial" play, and even their unscrewable lens groups are absolutely stable when screwed onto...
  • 2 weeks later...
I have a tele-Elmar 135 that does it.
That's a relief. My 135 TE has some slight play in the focusing barrel as well.
I can unscrew the lens head and it is rock solid.
Wide open at close focus distance of 1.5 m my 135 TE seems to front focus by about 2 cm but otherwise seems to be on the mark.
I wonder whether it needs adjustment?
K-H.
This is a very difficult lens to adjust, as it is not shimmed. The only way to do that is to rotate the optical cell mount relative to the helicoid, and then counterrotate the focus ring assembly to straighten it out. Will van Manen just did mine.
Thanks for the info. I just received a 135TE back from a CLA and it is still front focusing 1-2cm. It was 2-3 before. It is clean and smooth now, and I think I am just going to live with the front focus for now.
  • 2 weeks later...
