Transfer of Files Direct from M9 to Mac via USB
MHK
Has anyone had any trouble transferring files directly from the M9 to a Mac via a USB cable? When I try and do this, the camera freezes after the 2nd or third image on the card attempts to transfer. If I use a card reader, no issues whatsoever. I have tried switching SD cards to one of the compatible cards listed by Leica, and I still have the issue. Any thoughts appreciated.
I have had the same experience. USB doesn't seem to work reliably on the M9. Leica needs to fix that.
Too bad the eye-fi card is not compatible either with the M8, according to the manufacturer's website.
http://support.eye.fi/product-info/camera-compatability/compatibility/is-the-eye-fi-card-compatible-with-my-camera/leica/
I would think something similar applies to the M9?
I typically use Adobe's "Photo Downloader" which is part of Bridge. I launch it via the Dock, but it requires a little "hacking" to get to directly (outside of Bridge).
Right click on the "Adobe Bridge" application, select "Show Package Contents" from the contextual menu. Drill down into "MacOS" and there you will see "Photo Downloader." Just drag it to your Dock.
Or - a card reader.
+1 for the cardreader. One downside, though, is grabbing the camera for an outing, then finding out later the card reader still holds the card at home. I've done that 3 times now. I'm going to try to remember to leave the bottom plate off when the card is out of the camera.
Larry
Larry
M9 tells you if no card present when you switch on – no?
The little plastic door for the USB cable looks as fragile as that on the M8: another reason why it's far better to use card reader. It's not that much trouble and you avoid any download glitches.
At least I am glad to hear that it is a common issue. Sounds like the card reader is the way to go until a fix with the firmware. But, what a pain, to have to remember to bring a reader with me when I travel!
Hi MHK
There is a well documented bug . . . Leica are apparently aware of it, and I would imagine that it will be fixed in the first firmware update.
in the meantime - use a card reader!
No need for a card reader. Just use Apple's native app Image Capture and do not set the USB mode of the M9 to mass storage. Works great.
Thanks for your advice. I tried it and it seems to work like a charm indeed.
With best regards, k-hawinkler
A good look at that website suggests that they used a M8 with old - not SDHC compatible - firmware. There is a whole page explaining the diffenerce between Sd and SDHC.
Or is it the fact that the M8 house is metal and not plastic
Thanks for the feedback. I don't know. Hopefully eye-fi will update their website soon with M9 information as well.
Strange that it would work with the native app image capture and not right into Aperture. Any idea how to reset the automatic settings so that App Image Capture comes up when the camera is plugged in rather than Aperture?
You run Image Capture, go to Preferences and select which application should be run when a camera is connected.
Here is a quote: "... I use a WiFi-enabled memory card in my camera, so I transmitted the picture back to the paper seconds after I made it, thinking I had captured something that the readers of the Times would appreciate ..."
from
My photo gets skewed - St. Petersburg Times
Pretty interesting I would say.
