arnaudhaifa Posted September 21, 2007 Share #1 Posted September 21, 2007 Advertisement (gone after registration) I couldn't find in previous threads a answer to this question: Using my new tri elmar without filter but with the ir menu on for exif datas I obtained pink/orange corners surely due to vignetting corrections, Is there a way to obtain the correct exif infos about lens without filter and therefore the pink corners? Do you know how to correct these colors corner using lightroom? Many thanks, Arnaud Link to post Share on other sites More sharing options...
Advertisement Posted September 21, 2007 Posted September 21, 2007 Hi arnaudhaifa, Take a look here WATE and pink corners . I'm sure you'll find what you were looking for!
EricC Posted September 21, 2007 Share #2 Posted September 21, 2007 Hi Arnaud, As far as i know you can always use CornerFix available here : http://www.l-camera-forum.com/leica-forum/leica-m8-forum/34270-cornerfix-0-9-1-3-now.html and designed and built by Sandy McGuffog of this very Forum. You will have to create your own profiles to use, but as i found out when i tried, it is not too hard. Regards Eric Link to post Share on other sites More sharing options...
jaapv Posted September 21, 2007 Share #3 Posted September 21, 2007 If you use the lens without filter but with the IR filter setting on, the camera will correct as if there is a filter on- resulting in pink corners. Switch the camera to "lens detection on"and only use the IR setting if you really have an IR filter on it. Link to post Share on other sites More sharing options...
arnaudhaifa Posted September 21, 2007 Author Share #4 Posted September 21, 2007 THANK YOU Eric and Jaap! Very friendly and efficent Forum! Link to post Share on other sites More sharing options...
ArtZ Posted September 21, 2007 Share #5 Posted September 21, 2007 Arnaud, You will get also some important information about this issue here: http://www.leica-camera.us/assets/file/download.php?filename=file_2895.pdf FAQ LEICA M8 // Sept 2007 85,9 KB PDF Regards; . Link to post Share on other sites More sharing options...
