roylance Posted April 30, 2011 Share #1 Posted April 30, 2011 Advertisement (gone after registration) Came home after a shoot, M8 is off, removed the bottom plate, removed the card and the little red light started flashing and beeping. I thought this is odd. Transferred the images, put the card back in and a charged battery, and turned the camera on. I wanted to go into the menus to see how the camera was configured BUT the LCD does not illuminate stays black regardless of what I do and no battery indicator. Here is the odd thing if I remove the bottom plate turn the camera on to S remove the battery and put it back in I get the message ‘Attention Bottom Plate…’ put the bottom plate on, I get the battery indicator and can shoot. But still not LDC menus. When I shoot in S it does not sound as if the shutter returns, but I get an image on the LCD, if I turn the dial to C, I hear the sound of the shutter returning. When I shoot in C the shutter sounds normal, but no image on the LCD. This happens with 3 batteries, 1 is new and just used today. I have cleaned the battery terminals in the camera and still no luck. I did have to press the shutter after turning it on for it to come alive. Thoughts and or solutions appreciated. Link to post Share on other sites More sharing options...
Advertisement Posted April 30, 2011 Posted April 30, 2011 Hi roylance, Take a look here M8 problems . I'm sure you'll find what you were looking for!
RichardM8 Posted April 30, 2011 Share #2 Posted April 30, 2011 Errr... Gosh that does sound like pretty mixed up M8... Link to post Share on other sites More sharing options...
lct Posted April 30, 2011 Share #3 Posted April 30, 2011 Smells like a camera problem i'm afraid but Discreet (menu "Advance") and Continuous ("C") modes are not compatible. I would stay in Single ("S") mode or disable Discreet and see what happens. Otherwise i would do a full batterry discharge (until the camera stops) then a full recharge and see what happens. Link to post Share on other sites More sharing options...
roylance Posted April 30, 2011 Author Share #4 Posted April 30, 2011 Smells like a camera problem i'm afraid but Discreet (menu "Advance") and Continuous ("C") modes are not compatible. I would stay in Single ("S") mode or disable Discreet and see what happens. Otherwise i would do a full batterry discharge (until the camera stops) then a full recharge and see what happens. Problem is without the LCD I have no access to the menus, so I can not change the auto off after 2 minutes (or what ever I set) or Discreet mode. Link to post Share on other sites More sharing options...
lct Posted April 30, 2011 Share #5 Posted April 30, 2011 You're good for a full discharge tonight + a full recharge tomorrow then. Another idea could be to remove the battery and let the camera as is for a couple of days. This will drain the internal battery and should cause a full system reset if the M8 works like my other digicams. Link to post Share on other sites More sharing options...
roylance Posted April 30, 2011 Author Share #6 Posted April 30, 2011 You're good for a full discharge tonight + a full recharge tomorrow then. Another idea could be to remove the battery and let the camera as is for a couple of days. This will drain the internal battery and should cause a full system reset if the M8 works like my other digicams. Thanks I will try both. Link to post Share on other sites More sharing options...
lct Posted April 30, 2011 Share #7 Posted April 30, 2011 Advertisement (gone after registration) ...This will drain the internal battery and should cause a full system reset if the M8 works like my other digicams. Letting the camera switched on during the wait of course. Link to post Share on other sites More sharing options...
Bert N Posted April 30, 2011 Share #8 Posted April 30, 2011 According to this thread, the internal battery will last much longer than a couple of days. In any case, the reported problem doesn't sound like it can be addressed by a simple reset. You're good for a full discharge tonight + a full recharge tomorrow then. Another idea could be to remove the battery and let the camera as is for a couple of days. This will drain the internal battery and should cause a full system reset if the M8 works like my other digicams. Link to post Share on other sites More sharing options...
lct Posted April 30, 2011 Share #9 Posted April 30, 2011 ...In any case, the reported problem doesn't sound like it can be addressed by a simple reset. Too bad... What's your advice to the OP then? Link to post Share on other sites More sharing options...
Bert N Posted April 30, 2011 Share #10 Posted April 30, 2011 If I were him, I'd promptly contact Leica service and ask for their advice. Too bad... What's your advice to the OP then? Link to post Share on other sites More sharing options...
roylance Posted May 1, 2011 Author Share #11 Posted May 1, 2011 Thanks Bert, I will call Leica tomorrow, after I see if leaving the camera on for 48 hours without a battery. If I were him, I'd promptly contact Leica service and ask for their advice. Link to post Share on other sites More sharing options...
Bert N Posted May 1, 2011 Share #12 Posted May 1, 2011 I hope they will quickly resolve your issue. This thread covers a similar issue with a happy ending shortly after... Link to post Share on other sites More sharing options...
roylance Posted May 2, 2011 Author Share #13 Posted May 2, 2011 Camera is off to Leica... 3 - 4 week turn around. I hope they will quickly resolve your issue. This thread covers a similar issue with a happy ending shortly after... Link to post Share on other sites More sharing options...
jberry Posted May 3, 2011 Share #14 Posted May 3, 2011 Sorry to hear that roy lance. Please let us know the outcome! Link to post Share on other sites More sharing options...
roylance Posted May 3, 2011 Author Share #15 Posted May 3, 2011 Will do, the M8 is on it's way and should arrive at Leica NJ tomorrow and I should have an estimate in 2-3 days after that. Sorry to hear that roy lance. Please let us know the outcome! Link to post Share on other sites More sharing options...
roylance Posted May 10, 2011 Author Share #16 Posted May 10, 2011 Update it is a bad circuit board and will take 5-6 weeks at Leica USA. Link to post Share on other sites More sharing options...
jberry Posted May 10, 2011 Share #17 Posted May 10, 2011 Thanks for the update. Similar thing happen to me, my M8.2 frooze couple days ago, because I was doing 'Continuous' when 'Discreet' was enabled. Had to take out battery, and let it sit for a couple hours while the battery was charging. Then it worked. Link to post Share on other sites More sharing options...
roylance Posted May 11, 2011 Author Share #18 Posted May 11, 2011 If only mine would have fixed itself that way. I had the battery out for 2 days with the camera on. Glad yours worked. Thanks for the update. Similar thing happen to me, my M8.2 frooze couple days ago, because I was doing 'Continuous' when 'Discreet' was enabled. Had to take out battery, and let it sit for a couple hours while the battery was charging. Then it worked. Link to post Share on other sites More sharing options...
spylaw4 Posted May 11, 2011 Share #19 Posted May 11, 2011 Thanks for the update. Similar thing happen to me, my M8.2 frooze couple days ago, because I was doing 'Continuous' when 'Discreet' was enabled. Had to take out battery, and let it sit for a couple hours while the battery was charging. Then it worked. Am I wrong, or was not 2.005 supposed to fix the Continuous/Discreet problem? Link to post Share on other sites More sharing options...
euroveto Posted May 11, 2011 Share #20 Posted May 11, 2011 I try to make starve mine for 5 days, but it didn't fix the problem. I sent it to Solms today it appears after a very smaall shock on the ground, from a suitcase 10 cm tall Link to post Share on other sites More sharing options...
