| Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants! |
#1 (permalink) |
Erfahrener Benutzer
Hi, I am looking for one of these. Barrel can show a little wear but glass needs to be free of haze, fungus etc. Any clues of where to find one? I can trade with the same lens in bayonet mount or in M3 version + some cash if necessary...
(to Moderators: there were no "wanted" section in the screw mount classifieds...)
__________________
Gunnar |
#2 (permalink) | |
Erfahrener Benutzer
Hi,
Quote:
![]() Are You sure your lens is not already a screw one ? Many have been changed for the M3 by adding an adapter ring on it. A very small screw can be seen down (6 o'clock) on those "multi-mount" lens. ![]()
__________________
Φilip |
#4 (permalink) |
Erfahrener Benutzer
There is one listed at Aperture Photographic Aperture Photographic Tel. 020 7242 8681 Fax. 020 7242 8680
£490 which seems a bit expensive ... but I have known them to haggle . Cheers dunk
__________________
Every day has its dog ... |
#5 (permalink) |
Erfahrener Benutzer
Leicashop in Vienna has four listed: https://www.leicashop.com/main.php?l...kat=02&kat2=04
- Carl PS: Wibergs Foto in Sthlm has two, but they are the f:3.5 Last edited by cbretteville : 03/13/08 at 09:55 AM. |
#6 (permalink) |
Erfahrener Benutzer
Thanks for the replies!
I already have the 3.5 version. I like the way the 2.8 draws and I want to make a tiny "in the pocket" setup with the IIIb + Summaron 2.8 (+ maybe the SBLOO).
__________________
Gunnar |
#8 (permalink) |
Erfahrener Benutzer
Hello Luigi!
I did see your PM, thanks! I have received a few offers and will let you know what I decide to do. Actually I am uncertain if I have the adapted version or not. There are three screws on the rear ring but there is nothing that look anything like the regular 1mm LTM adapter. Best,
__________________
Gunnar |
#11 (permalink) |
Erfahrener Benutzer
Hello Gunnar,
Yes you can use the first one, just unscrew the little screw which is on the flange the one we see on the picture, let a drop of penetrating oil on the head for a while before, next you can use a rear cap to unscrew the M flange and next after cleaning the thread with lighter fluid and using some moly grease you can use it on a LTM body. The one for M3 is useable too, but you do not to use it Good luck (you are lucky anyway)
__________________
regards JC Last edited by jc_braconi : 03/13/08 at 08:07 PM. |
#12 (permalink) | |
Erfahrener Benutzer
Quote:
![]() This IS here the small scew i meant... Maron35.jpg I told You, most people don't know. ![]()
__________________
Φilip |
#13 (permalink) |
Erfahrener Benutzer
Thanks JC and Philippe!
How about the larger screw on the second picture of the M2 version? Should I just leave that alone? Philippe - sorry for not looking close enough when you mentioned this the first time... I was looking for something more like the traditional LTM to bayonet adapter...
__________________
Gunnar |
#14 (permalink) |
Erfahrener Benutzer
Hi Gunnar,
Found some: Schouten Select Cameras & Accessories! Barrel shows signs of use specially on the front ring. Elements are clean. Hope this is still some help All the best Ruben |
#15 (permalink) |
Erfahrener Benutzer
OK, Gunnar, my PM'd proposal is nonsense, given the lenses you have... mine is exactly as your 2nd item, deprived of BM adapter and goggles (and this, as JC said, is a pity to do, much better to make the removal on the first item, as Philippe said too)
#16 (permalink) |
Erfahrener Benutzer
Ruben - Thanks
Luigi - Well, my knowledge about these items is only a fraction of yours, JCs, Philippes and all the other helpful members of this forum. So, I had no idea that I could use what I already have. Thanks everyone, I learn something from this place every day. ![]()
__________________
Gunnar |
#20 (permalink) | |
Erfahrener Benutzer
Quote:
![]() Last edited by luigi bertolotti : 03/14/08 at 07:40 AM. |
