Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Register now
Old 03/14/08, 09:56 AM   #21 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
Default Re: AW: Summaron 35/2.8 screw mount
Quote:
Originally Posted by telewatt View Post
.... ...wow...thats fine...
my Summicron 8 elements will work for the same?... I saw 3 screws...
regards,
Jan
Hi Jan,
Post a pict, please, of your lens, so WE can see these 3 screw....
__________________
regards
JC
jc_braconi @ LFI Gallery
jc_braconi is online now   Reply With Quote
Old 03/14/08, 10:50 AM   #22 (permalink)
Erfahrener Benutzer
telewatt's Avatar
Default AW: Summaron 35/2.8 screw mount
Hello Luigi and JC..
here is a picture of the lens.
there are only the 3 big screws...
I'm not to happy to crew to much on this beauty!...
regards,
Jan
__________________
http://www.scheffner-foto.de
telewatt is online now   Reply With Quote
Old 03/14/08, 10:55 AM   #23 (permalink)
Erfahrener Benutzer
Philippe D.'s Avatar
Hallo Jan,
I'm afraid not.
The ring-adapter (left) comes in a recessed space (blue arrow),
it is then fixed into place with a very small screw that comes here (red arrow).
The 3 screws you mean are those one (one of them here, green arrow).
Those screws should better not been unscrewed.
__________________
Φilip
Philippe D. is offline   Reply With Quote
Old 03/14/08, 10:58 AM   #24 (permalink)
Erfahrener Benutzer
If you don't see a very little one on the bottom ring (with the red dot), then you have an M bayonet lens.
__________________
Φilip
Old 03/14/08, 11:14 AM   #25 (permalink)
Erfahrener Benutzer
telewatt's Avatar
Thanks Philippe...!
o.k. no Summicron on my IIf... ..
regards,
Jan
__________________
Old 03/14/08, 01:17 PM   #26 (permalink)
str
Erfahrener Benutzer
str's Avatar
Another picture with a 2.8/35 Summaron, you see the screw at the
bayonett:
Stefan
str is offline   Reply With Quote
Old 03/14/08, 02:29 PM   #27 (permalink)
Erfahrener Benutzer
luigi bertolotti's Avatar
Thanks Philippe...!
regards,
Jan
Don't worry Jan... it's anyway a "8 elements Wetzlar"... a precious lens by its own... my one (1.971.xxx) does have the famous tiny screw, but I prefer not to dismount... is still an enjoyable lens on M8...
The screw mount items, seem to remember, were 500 or less..
luigi bertolotti is offline   Reply With Quote
Old 03/14/08, 03:54 PM   #28 (permalink)
Erfahrener Benutzer
telewatt's Avatar
Default AW: Re: AW: Summaron 35/2.8 screw mount
You are right Luigi... ..I love it...I have the ASPH too, but some time I prefer this on!
Regards,
Jan
__________________
Old 03/14/08, 05:10 PM   #29 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
Default Re: Summaron 35/2.8 screw mount
Jan,
I think everything was told, may be you can find one in the next days,
good luck
__________________
regards
JC
Old 03/22/08, 02:08 AM   #30 (permalink)
Erfahrener Benutzer
echorec's Avatar
I am a little tempted to try this on my M3 Summicron too. The screw is there. Should I dismount the googles first then the little screw?
Thanks,
__________________
Gunnar
echorec is offline   Reply With Quote
Old 03/22/08, 03:30 AM   #31 (permalink)
Erfahrener Benutzer
doubice's Avatar
Quote:
Thanks,
Gunnar,
Before you start disassembling your Summicron - a few tidbits of information on the 35mm Summicron and f:2.8/35mm Summaron 'goggled' lenses.
They all focus to 70cm, even with the M3's rangefinder, which was only designed to focus to 1 meter. The goggles change the optical properties of the M3's finder to do this. To compensate for this, the rangefinder cam and internal focusing helicoid of all 'goggled' lenses are cut at a different angle - the lens will thus not couple to the rangefinder properly when the goggles are removed.
You might be able to 'guess focus' the lens but, on the examples that I tried, even the focusing scale sometimes did not match the actual distance once the goggles were removed.
You will of course not encounter this problem on any of the 'non-goggled' convertible (M to LTM) lenses. This is because their rangefinder cam and focusing helicoid are cut to work with all Thread Mount and M camera's rangefinders.
Hope it makes sense....
All the best,
Jan
doubice is offline   Reply With Quote
Old 03/22/08, 04:10 AM   #32 (permalink)
Erfahrener Benutzer
echorec's Avatar
Hello Jan,
That makes sense, maybe I should leave it as it is and just be happy with my Summaron "conversion".
Thanks,
__________________
Gunnar
Old 03/22/08, 09:55 PM   #33 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by doubice View Post
Gunnar,
All the best,
Jan
Jan, how does that work with the original 35/3.5 Summaron for the M3, some of those had removable goggles so they would also work on the M2. Do they have the 'normal' cam and are thus not able to focus to 70cm on the M3?
Gerry
gyoung is online now   Reply With Quote
Old 03/22/08, 11:30 PM   #34 (permalink)
Erfahrener Benutzer
doubice's Avatar
Hi Gerry,
Regards from Vancouver! I am sure you do not miss Montreal - over 2 meters of snow accumulation this winter……..
As to the goggled 3.5/35mm Summaron, even though that was my first 35mm lens on my first M3, I don’t recall how the cam worked with the goggles removed. The M2 was introduced after the discontinuance of the 3.5 Summaron so, I don’t think the goggle’s removeability (is that a word?) was there to allow the lens’ use on the M2. It was probably made that way just for ease of manufacture, even though in those years Leica did not care much about that…….
There also was a 3.5/35mm M mount Summaron without the eyes - it, like the goggled lens, keyed in the 50mm frame and was meant to be used on the M3 with an external shoe-mounted finder. That lens could be used on the M2 without any problems if one filed the frame actuating bayonet lug down - that would prevent any frames from being keyed in and the default frame on the M2 was 35mm. I am in the office and do not have access to my Leica ‘bibles’, so can’t tell how close the 3.5 Summaron focused with the goggles - the non-goggled one focused to 1meter.
Maybe Luigi will have a better answer?
All the best,
Jan
Old 03/23/08, 12:33 AM   #35 (permalink)
Erfahrener Benutzer
jc_braconi's Avatar
You can only remove the goggles on the infinity position and when removed the focusing ring is blocked, if you want to unblocked it you have to push on the little ball.
I think that the possibility of removing the goggles was only made for easying the storing in case like the shell shaped one.
What is sure is when you use the 3.5 / 35 Summaron without the goggles on the M2 the viewfinder frame line set by the bayonnet cam is the one for the 50mm.
Same for the classic 3.5/35 (without goggles, to be used with the SBLOO viewfinder)
The only way to get the 35mm frame line is to use the 3.5/35 in screw mount version and use the adaptor ring for it.
__________________
regards
JC
Old 03/23/08, 01:48 AM   #36 (permalink)
Erfahrener Benutzer
doubice's Avatar
Thanks, JC!
My memory was refreshed after reading your post. I do recall the little pin that was depressed when the goggles were slid into position and thus unlocked the focusing mount. Yes, the only reason for the goggles' removal was to make it easier to store the lens. It would not focus correctly without the goggles on any M Leica - that is why the focus was locked when the goggles were removed.
Basically the same idea as the locking system on the DR Summicron - you can only focus in the close range when the goggles are attached and cannot focus further than 1 meter with the goggles in place.
Best,
Jan
Old 03/24/08, 05:41 PM   #37 (permalink)
Erfahrener Benutzer
Thanks, JC!
Best,
Jan
Thanks both, I new the removal of the goggles locked the DR Summicron, but I hadn't remembered that it did on the Summaron. Its 40 years since I saw that version (in Montreal!). I am going to London in a couple of weeks, I shall take a very close look at the 2.8/35s on sale in case I can find an early M one with removable bayonet mount, the screw one gets a very high premium here in the UK.
It has been snowing here in England this weekend, not completely unknown but unusual this late.
Gerry
Old 03/27/08, 01:46 AM   #38 (permalink)
Erfahrener Benutzer
echorec's Avatar
Picture taken with the IIIb + Summaron:
http://www.l-camera-forum.com/leica-...est-march.html
__________________
Gunnar
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
