echorec Posted February 25, 2008 Share #1  Posted February 25, 2008 Advertisement (gone after registration) Good evening Gentlemen,  Do you think it is possible to unlock the fixed-focus Summaron and use it as a normal lens?  It looks like I could just loosen the little screw where the focusing lever usually is but I thought I would ask here first before damaging anything.  I used to have a regular 28/5.6 which I sold and I regret that sale everytime I see pictures I took with that lens... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/46338-unlocking-the-post-summaron-2856/?do=findComment&comment=492906'>More sharing options...
Advertisement Posted February 25, 2008 Posted February 25, 2008 Hi echorec, Take a look here Unlocking the "post" Summaron 28/5.6?. I'm sure you'll find what you were looking for!
luigi bertolotti Posted February 25, 2008 Share #2 Â Posted February 25, 2008 Gunnar, I think you could do it without problems... but this isn't based on any direct experience on the Post Summaron... I'd suggest to loosen the screw... verify if the helicoid moves clean (suppose, say, Leitz wouldn't have lubricate the items delivered with Postkameras...)... assure you can reverse well the process... would be a pity to "cannibalize" a lens that is a valuable collector's item. Â ... wouldn't you exchange your Post Summaron for a fine prewar Hektor 2,8 ? ... just an idea...I have one.... Link to post Share on other sites More sharing options...
jc_braconi Posted February 25, 2008 Share #3 Â Posted February 25, 2008 Yes you can, just find the right screwdriver for the slot and may be let a drop of penetrating oil for 24 hours on the head screw Link to post Share on other sites More sharing options...
echorec Posted February 25, 2008 Author Share #4 Â Posted February 25, 2008 Thanks Luigi & JC, Â I will give it a try. Â Thanks for your offer Luigi but I think I will hang on to this one. I like the way it draws and this one has clean glass. The one I sold was slightly hazy but produced nice results anyway. Link to post Share on other sites More sharing options...
giordano Posted February 25, 2008 Share #5 Â Posted February 25, 2008 It looks as if the focusing helical is locked in the infinity position - but as I understand it the lenses were used for photographing metering equipment at fairly close range. So presumably there's some sort of shim in the mount to provide the necessary extension, and you'll need to remove that to get infinity focus. Â Does the lens have a rangefinder cam? Link to post Share on other sites More sharing options...
luigi bertolotti Posted February 25, 2008 Share #6 Â Posted February 25, 2008 Gunnar... can you post a pic of the back ? Lokking well your 1st pic, seems to be something strange in the Screw to Bayonet adapter... maybe simply a photo effect... but I am curious to see... (and so better if also the s/n is visible...) Â My offer for the Hektor was a semijoke... anyway I don't want to separate it from me... was my 2nd Leitz lens after the Elmar 5.... Link to post Share on other sites More sharing options...
echorec Posted February 25, 2008 Author Share #7 Â Posted February 25, 2008 Advertisement (gone after registration) John, there is a shim indeed, thanks for pointing that out. Â Luigi, the shim is what you see in the first picture. It was tightly screwed in between the lens and the LTM to bayonet adapter but I managed to remove it. Â I also removed the small locking screw and the focusing is very smooth so no need for oil. Â Finally, I mounted the lens without the shim on a normal M camera and the rangefinder coupling seems spot-on. Â All I need now is a little knob (preferably Leitz original) for the focusing that fits where the locking screw was. Any ideas? I can focus it now with my fingernail but a knob would be more convenient and look better too. Â Luigi, I can take a picture of the back tomorrow (and sorry for not getting the semi-joke ), Â Thanks for all your help, Link to post Share on other sites More sharing options...
luigi bertolotti Posted February 26, 2008 Share #8 Â Posted February 26, 2008 Gunnar, for the knob... I think the best way to have an original is chasing for a very bad Elmar or Summar... they can be very cheap and have a knob... have no idea if the transplant is easy to do; to continue with my offerings (but this is serious... ), I have a very bad and hazed/scratched Elmar Red Scale: no problem to give it away for almost nothing, if you don't find anything next to home: tell me, via PM in case, if can be a solution. Link to post Share on other sites More sharing options...
echorec Posted February 26, 2008 Author Share #9 Â Posted February 26, 2008 Hello Luigi, Â Thanks for your offer, I will send you a PM. Â Best, Link to post Share on other sites More sharing options...
echorec Posted February 26, 2008 Author Share #10  Posted February 26, 2008 Here is the back. I could not find the serial number. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/46338-unlocking-the-post-summaron-2856/?do=findComment&comment=493609'>More sharing options...
echorec Posted February 26, 2008 Author Share #11  Posted February 26, 2008 Ok, time to go out and take some pictures...  I found an old 9cm LTM adapter that (naturally) brings up the 28mm framelines on the M6. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/46338-unlocking-the-post-summaron-2856/?do=findComment&comment=493723'>More sharing options...
luigi bertolotti Posted February 26, 2008 Share #12 Â Posted February 26, 2008 Sure that the s/n isn't there ? Isn't easy to find... should be finely engraved in the inmost black part of the mount..."conic-shaped".. visible with a strong lght well positioned... Â Â ... in the meantime your splendid pic of the M6 + Summaron has arrived ....WOW !!! Link to post Share on other sites More sharing options...
leitz_not_leica Posted February 28, 2008 Share #13 Â Posted February 28, 2008 Sweet old school lens. Are you sure close focus is OK? These lenses, which are not meant to be focused MAY have not had their cams ground to match the focal length. A 28 should not be much of a problem, though. Link to post Share on other sites More sharing options...
echorec Posted February 29, 2008 Author Share #14  Posted February 29, 2008 We´ll see. I have a roll off Tri-X in the camera and I´ll report back when it´s developed. Link to post Share on other sites More sharing options...
echorec Posted March 5, 2008 Author Share #15  Posted March 5, 2008 Here is a simple test shot with focus at 1 meter and aperture 5.6 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/46338-unlocking-the-post-summaron-2856/?do=findComment&comment=501656'>More sharing options...
cbretteville Posted March 5, 2008 Share #16 Â Posted March 5, 2008 Looks functional to me. - Carl Link to post Share on other sites More sharing options...
