Summarit 1.5f 5cm
John T Barrett
x
Any suggestions for modern filters for Summarit 1.5f 5cm lens (i.e size, need for adapter, manufacturer and source of supply)?
JTB
John,
The Summarit's filter size is 41 x 0.5, meaning 41mm screw-in with a 0.5mm pitch. No adapter is needed for those. Some of the earlier Summarits used to take special Leitz bayonet mount filters - those are only available used and obviously, choice will be very limited. I would stay away from those.
B+W, Heliopan and Hoya would be the obvious choices and Google should be your friend as to availability.
Best,
Jan
Actually, you can take a bayonet filter, knock out the glass and "screw"in a 40.5 mm filter. It is very practical for filters one seldom uses. (like a 408)
