Leica User Forum Classic Connection
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Register now
Old 06/18/08, 01:53 PM   #1 (permalink)
Erfahrener Benutzer
stnami's Avatar
Default Leica 21mm /4 Super Angulon -R Lens
Leica 21mm f/4 Super Angulon R Lens
what's it like, colour rendition wise etc............ ?
__________________
“doi knia”
ETROUKO
slide shows http://www.artouko.com/
stnami is offline   Reply With Quote
Old 06/18/08, 07:31 PM   #2 (permalink)
Erfahrener Benutzer
Default Re: Leica 21mm /4 Super Angulon -R Lens
Going by memory here, it was a little warmer than the true Leica-made lenses (it's a Schneider) but not a lot. Pretty soft in the corners until f/8, and tendency for flair. Not great closeup either unless stopped way down. It had a weird aperture, like just 4 blades or something. Otherwise very sharp, and good contrast, considering it was designed back in the Johnson administration (Lyndon, not Andrew ) . IF your useing it on a DMR the crop factor will clean up a lot of the abberations, and the color balance should be no problem to shore up either.
jimmy pro is offline   Reply With Quote
Old 06/18/08, 08:48 PM   #3 (permalink)
Erfahrener Benutzer
roguewave's Avatar
Go for the R19 (Type II) on the R system. The 15 is way cool, but a pretty narrow range. Since you already put your subjects thru contortions (I LIKE IT), it probably won't give you want. The 19 will, based on what I've produced and what I've seen (before gone) of your work. I have both R 19's & love them equally. The older one can be bought now for about $550 US if you know Ebay well. It has a very wonderful way of softening up the harsh light, particularly in B&W. The more modern (Type II) is a work horse. Awesome color, contrast. Clearly a more modern look & signature. I alway have one on an R8, either for film or DMR. Up close, I mean real up close, portraits have no real distortion. You'd love it. I do.
__________________
Ben
~~~~ _/) ~~~
Roguewave @ LFI Gallery
roguewave is offline   Reply With Quote
Old 06/18/08, 11:08 PM   #4 (permalink)
Erfahrener Benutzer
liesevolvo's Avatar
Default AW: Leica 21mm /4 Super Angulon -R Lens
Yes, 4/21 has a 4-blades-aperture; ugly like an old TV-screen.
Yes, 4/21 tends to bad reflections (look at the size of front-lens!).
Yes, the quality of lenses spreads more than usual for a Leica-lens (because it is Schneider?!?!)
Yes, this lens is GREAT, at least MINE!
Leonard Liese, Cologne, Germany
liesevolvo is offline   Reply With Quote
Old 06/18/08, 11:50 PM   #5 (permalink)
Neuer Benutzer
kixigvak's Avatar
I've never had the 21, but I've owned both the older 19 and the new one. I use the current 19 Elmarit a lot. Both are fabulous lenses. I once had a drum scanner operator in Munich call me to ask what lens I'd shot a photo with. He couldn't believe the quality. It was the 19.
James Mason
Alaska, USA
kixigvak is offline   Reply With Quote
Old 06/19/08, 12:26 AM   #6 (permalink)
Erfahrener Benutzer
stnami's Avatar
Thanks ........ my intent was to use it for both the Leica R ( someone offered a 4 for 250 aussie pesos, works great cosmetically ordinary), as a wide and Oly E digital (2x 21 = 42 mm) a nice focal length for me these days on digital
Is the 4 ok or are there better using it sparingly
__________________
“doi knia”
ETROUKO
Old 06/19/08, 02:58 PM   #7 (permalink)
lct
Erfahrener Benutzer
lct's Avatar
... Is the 4 ok or are there better using it sparingly
Some electronic issues have been reported between 1980 and 1982.
Better avoid smaller serial numbers than 1,600,000.
No such problems with the simpler R4s though but it has no program mode, no shutter speed priority AE and shutter speeds are not displayed in the VF in manual mode.
I own a R4s btw. Small body, quiet shutter noise, large and bright VF, exactly what i dream about for the R10 or a possible R10s.
For French readers, see LEICA R4 MOT, R4, R4s, R4s2 (R4sP)
lct is offline   Reply With Quote
Old 06/19/08, 04:07 PM   #8 (permalink)
Erfahrener Benutzer
garyp's Avatar
I bought one in 1983. still have it, one of my most used lenses.
It's one I will probably never get rid of.
Yes, it's best stopped down to f8 or so, it's a great lens with Kodachrome.
garyp is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
