Leica User Forum Red Dot Cameras
Go Back   Leica User Forum > International User Forum > Customer Forum
Startseite Register FAQ Members List Calendar Mark Forums Read
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more spcialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old February 11th, 2008, 09:10 PM   #1 (permalink)
Benutzer
Default Plane Scanners
Hi, I'm a black and white photographer. I need to digitalized my photos to send them in a digital way either e-mail or via web.
I thought to buy a scanner, a plane scanner; I've seen a lot of them by Epson. I need a good quality one. The only problem I have is that all the scanners I've seen scan the A4 format which should be approximately a 21X29cm meanwhile my print are 24X30. What can I do? Do you have any suggestions?
Annibale
Annibale G. is offline   Reply With Quote
Old February 11th, 2008, 09:28 PM   #2 (permalink)
Erfahrener Benutzer
stunsworth's Avatar
Default Re: Plane Scanners
Hi Annibale, I assume you're are scanning prints. Is that correct? If so you'll need an A3 scanner rather than the normal A4. If you Google 'A3 scanner' you should see what you're looking for.
An alternative of course is to scan the original negatives.
__________________
Steve
Website - www.steveunsworth.co.uk
Picture a week - http://www.steveunsworth.co.uk/PAW_blog/?page_id=9
stunsworth is offline   Reply With Quote
Old February 12th, 2008, 07:06 AM   #3 (permalink)
Benutzer
well , I need to scan prints right. I've already have a negative scanner. But the work you have to do with is too much.
Annibale
Old February 12th, 2008, 07:40 AM   #4 (permalink)
Erfahrener Benutzer
luigi bertolotti's Avatar
A3 Scanners are (obviously) big and generally costly (except the Musteks, fwiw the only rather cheap that are easily available in Italy): personally, having I a standard A4 flatbed, 4 o 5 times I scanned 24x30 pics making two A4 scans and then using photo stiching Software to rebuild the pic... not difficult, and you enjoy the resolution of the scanner, that for a good A4 is usually higher than on a cheap A3...of course, this has sense only if you already have the scanner and the stiching Software.
luigi bertolotti is offline   Reply With Quote
Old February 12th, 2008, 08:53 AM   #5 (permalink)
Erfahrener Benutzer
I am a black and white photographer too. I agree that it is almost pointless to try to scan b+w negatives.
Almost all my prints are 24x30 and I scan them on a standard A4 flatbed scanner. In practice this is possible because most A4 scanners have a scanning area that is slightly larger than A4; the width is usually US letter size plus a little bit for good measure.
My prints have a 2 cm white border on each side, but even with a much thinner border you will be able to scan the whole picture (not paper!) area.
A low cost scanner will do and will give excellent results if you scan from 24x30 paper. In practical terms, if you scan at high resolution, the files will be much too large for sending via email or publishing on the web.
I have a Canon scanner which I bought new for 99 Deutschmarks which says something about its age. It works very well but is a bit noisy. You cant go wrong with a 50 Euro investment. Try it!
christer is offline   Reply With Quote
Old February 16th, 2008, 12:15 PM   #6 (permalink)
Benutzer
I'll see . I thought about a epson ones.
Old February 16th, 2008, 12:59 PM   #7 (permalink)
Erfahrener Benutzer
earleygallery's Avatar
Why is it pointless to try and scan B&W negs?
__________________
Regards,
James
www.earleygallery.com
earleygallery is offline   Reply With Quote
Old February 16th, 2008, 02:22 PM   #8 (permalink)
Erfahrener Benutzer
rob_x2004's Avatar
I smell formic acid
rob_x2004 is offline   Reply With Quote
Old February 16th, 2008, 03:03 PM   #9 (permalink)
Benutzer
I don't wanna scan negs because after that it takes many post-production work with photoshop . I take a lot of photographs, I make the print to a professional lab . I need just to convert image digitally.
Old February 16th, 2008, 03:29 PM   #10 (permalink)
Erfahrener Benutzer
robsteve's Avatar
If the prints are large, you could use a copy stand and a digital camera.
robsteve is offline   Reply With Quote
Old February 18th, 2008, 10:10 PM   #11 (permalink)
Erfahrener Benutzer
Default AW: Plane Scanners
Actually there is software out there available that will stitch two scans taken with a small scanner to a single image at reasonable cost, but stitching takes time and yadiyadiya. Get an A3 scanner, work with a copy stand or scan the originals (slides/negatives).
zapp is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
