Intervalometer/Remote Trigger-R8/DMR??
troyfreund
Hey Folks,
Just wondering if any of you had ideas for how I could do a time-passage series of photos with my R8/DMR. I know I could do it back when I was shooting Nikon, but I don't know of a way to do this with my Leica system now. There's no info at the Leica website about such accessories and I'd really like to do this. Any thoughts?
Troy
<- troy freund ->
Troy, what you are looking for is called the "Leica Remote Control RC-R8/R9", part number 14-202.
This device, as the name implies allows for remote control of the camera as well as functioning as an intervalometer.
With it you can take single frames or series shots scheduled in either seconds, minutes or hours to a maximum of 24 hours. If the camera motor drive is set to bracketing you will get the 3 exposures as usual at each activation. The desired number of exposures can be programed up to 99. The unit plugs into the 8 pin socket on the side of the motor drive (required) via a 15ft. cord. Extension cords are available in 15ft and 75ft. lengths with an operating maximum of some 300ft.
I would be happy to check out any operational requirements with the R-8 and DMR for you or you can look it up under the part number for more information. If you send me a message I will try to get back to you as soon as I can.
Hello, there.
I don't own a DMR (yet), but I read a thread in the german forum, about this issue. I'm interested in that topic as well. I didn't find the ink, but i'll try to summarize the discussion:
The remote only gives one signal. When the R8 is on, it shoots. When the R8/DMR is on stand-by, it only wakes it up - no image then.
So for longer intervals one must be sure to keep the DMR "alive" all the time.
This seems to be the bigger problem, because the power-supply doesn't support that.
However good luck!
Regards,
Torsten
Hey Guys, Gals,
The remote control arrived today. Comes with a long, 16-ft. cable and runs on a 9V battery. Silly thing doesn't even come with an instruction book. Bizarre. It is pretty self-explanatory though. At least I think I understand it so far. :) Neatest thing is that in the hand-held control, it displays your camera's operating mode, shutter-speed and aperture, metering system and exp. comp. KInda cool.
I'll let you know how my first experiments go with it.
Troy
Troy
Glad you were able to locate a remote control. I think you will like it. It is pretty straightforward to operate and fairly robust. Mind the battery case cover, it can warp a bit with an "oversize battery" and could break. Just be mindful to seat everything well and check your battery - some are a bit slimer than others.
Sorry you did not get an instruction book - I would ask B&H why it was not included.
At any rate, I would be happy to make and send you a copy as a PDF file. I think you will find it helpful.
Post me a message and include an email address and I will be happy to send a copy of mine - you will only need the "English" pages I assume. (For that matter I would be happy to send one to any other forum member who needs one.)
I made up a 100m extension cable for my R8/9 remote, as well as an infra red trigger (pics on my site below). Here are the connectors needed and the pin functions.
The connector is
Type: 711
Order no: 99-0479-100-08, from
binder-connectors - Binder, connector, circular connector
There is a pdf on the site for type 711 connectors showing the arrangement of pins.
The following pin out was provided to me by Leica Service in Solms.
Pin 1 is electrical Ground.
To activate the camera's meter: connect pin 1 to pin 8 for longer than 20msec.
To release the camera: connect pin 1 to pin 2 for longer than 120msec. Continuous connection will result in continuous release.
Once you have the pdf, trying shorting the respective pins on the motor drive or DMR and the camera will behave as indicated. :)
Be aware, soldering these connectors is not for those of use with fingers like Shrek. It can be done with care and a fine tipped soldering iron. Make sure you have the orientation of the pins right, for male and female ends. I had to re-do one of mine. :(
Also, 100m of cable is a pain to work with if it's not on a reel, or at least on a board to wrap in on.
It is fun to see what the camera is up to, and take shots from this distance. The critters react in funny ways when the black thing next to them goes 'clickety-flash' all of a sudden.
