kivis Posted September 27, 2009 Share #1 Posted September 27, 2009 Advertisement (gone after registration) Many opinions on this. Love to hear yours.Better to use nothing or a soft release on an M7? Link to post Share on other sites More sharing options...
Advertisement Posted September 27, 2009 Posted September 27, 2009 Hi kivis, Take a look here Soft release or mini or nothing for an M7?. I'm sure you'll find what you were looking for!
kenneth Posted September 27, 2009 Share #2 Posted September 27, 2009 I cannot see the need for any attachment on the shutter button of M cameras. I have M6's and assume the M7 shutter release button is the same. I shoot down to an eighth of a second hand held without any problem. It sounds to me like it is more of a holding the camera issue which might be the problem but there again I don't understand what your particular needs are or why you think one of these buttons would assist you to make better pictures. Can you go back to why you think you might need one? Link to post Share on other sites More sharing options...
rob_x2004 Posted September 27, 2009 Share #3 Posted September 27, 2009 With an M7 you probably dont need your finger on the shutter speed dial. On an MP my finger tip lives on the dial and I release the shutter with the inside of the first knuckle. I can do either independently, half depressing release to bring up the exposure meter. Two other things about using the first knuckle is that your grip is closer to the camera with your palm is snug to the body rather than the grip broken away, and secondly, if you press something with your fingertip you tend to pinch your thumb towards it as a result of a lifetime of picking things up. For long exposures you definitely dont want that. If I was given a soft release I would unscrew it and throw it in the bin. Link to post Share on other sites More sharing options...
chris roberts Posted September 27, 2009 Share #4 Posted September 27, 2009 I've used a soft release to good effect on an M4-P, M6 and M6TTL. However on my M7 there seems to be a different set-up within the shutter mechanism - probably to do with exposure locking with the 'first pressure point'. With a soft release attached, my shutter becomes 'notchy', which is the last thing you need when using slower speeds, so I've stopped using it on the M7. I believe this is not an uncommon issue with soft releases on this model. Link to post Share on other sites More sharing options...
MPerson Posted September 27, 2009 Share #5 Posted September 27, 2009 I was given two of these and tried them on my MP, M2 and CLs and I hated them. They are apt to act like a 'hair trigger' - especially on the MP when you have to go half way for metering. They can also trip the shutter when in a bag or moving them in and out of the bag. Link to post Share on other sites More sharing options...
budrichard Posted September 27, 2009 Share #6 Posted September 27, 2009 Nothing. I have two M7's, neither have 'soft releases' which are just after market money makers for someone. As pointed out the shutter button on an M7 has different functions as its depressed and requires no additional mechanism to function as designed. I wish my Nikon Fm3a had that feature.-Dick Link to post Share on other sites More sharing options...
stunsworth Posted September 27, 2009 Share #7 Posted September 27, 2009 Advertisement (gone after registration) I used a soft release on all my film Ms. Link to post Share on other sites More sharing options...
kivis Posted September 27, 2009 Author Share #8 Posted September 27, 2009 I've used a soft release to good effect on an M4-P, M6 and M6TTL. However on my M7 there seems to be a different set-up within the shutter mechanism - probably to do with exposure locking with the 'first pressure point'. With a soft release attached, my shutter becomes 'notchy', which is the last thing you need when using slower speeds, so I've stopped using it on the M7. I believe this is not an uncommon issue with soft releases on this model. I have used them on other rigs, so I am used to them, but on the M7 something just doen't feel right. I will live without it there. Link to post Share on other sites More sharing options...
Woodrow Posted September 28, 2009 Share #9 Posted September 28, 2009 Maybe not the M7, but a mini-soft release was just what was needed for the CL, as the shutter button sits down low.Hunting for it increased likelihood of camera shake. There is noted improvement since adding it. Link to post Share on other sites More sharing options...
bill Posted September 28, 2009 Share #10 Posted September 28, 2009 I have used them on other rigs, so I am used to them, but on the M7 something just doen't feel right. I will live without it there. Exactly my view. Regards, Bill Link to post Share on other sites More sharing options...
