joekurtz Posted September 16, 2009 Share #1 Â Posted September 16, 2009 Advertisement (gone after registration) This might be a silly question but can I use b+w uv/ir filters for lenses with the M8? OR do I need to buy Leica's uv/ir filters. I already have leica's filters for my 28 and 75 but what are my options for a CV 15 version2 52 mm filter size? Â I guess Marumi is another maker...are any better or worse for the M8. Â your help is appreciated. joe Link to post Share on other sites More sharing options...
Advertisement Posted September 16, 2009 Posted September 16, 2009 Hi joekurtz, Take a look here UV/IR for CV 15mm m-mount. I'm sure you'll find what you were looking for!
stunsworth Posted September 16, 2009 Share #2 Â Posted September 16, 2009 I use B+W 486 filters on almost all of my lenses and haven't noticed a problem so far. Link to post Share on other sites More sharing options...
como Posted September 16, 2009 Share #3 Â Posted September 16, 2009 I have a Heliopan uv/ir filter on my CV 15 and it works fine. B+W filters are also very good. There are several threads on how to mount these filters on a CV 15. Â Succes, Co Link to post Share on other sites More sharing options...
dNorm Posted September 16, 2009 Share #4  Posted September 16, 2009 I was told by a Leica authorized dealer that the M8/M8.2's firmware is tuned for Leica's IR/UV filters. Many have written that they get very good results from the B+W IR/UV filter, some have even said that they can't tell a difference. When using lenses of other manufacturer, who knows what variable that will play as well. I've also read that anything 24mm and wider should definitely be used with Leica's filter. Hopefully, someone who has the lens can comment. Cheers. -Norm  This might be a silly question but can I use b+w uv/ir filters for lenses with the M8? OR do I need to buy Leica's uv/ir filters. I already have leica's filters for my 28 and 75 but what are my options for a CV 15 version2 52 mm filter size? I guess Marumi is another maker...are any better or worse for the M8.  your help is appreciated. joe Link to post Share on other sites More sharing options...
wparsonsgisnet Posted September 16, 2009 Share #5 Â Posted September 16, 2009 Joe, I use both B+W and Leica filters. The B+W's are made by Schneider. Â I don't find a difference, either. Sean Reid measures differences in his lens/filter tests, but they look small. Â I wouldn't buy a cheap filter, tho. Stick to B+W or Leica. Â Regards, Link to post Share on other sites More sharing options...
joekurtz Posted September 16, 2009 Author Share #6 Â Posted September 16, 2009 Thanks all. I think I will go with B+W since it is not going to be a lens i use all the time. Link to post Share on other sites More sharing options...
epand56 Posted September 17, 2009 Share #7 Â Posted September 17, 2009 Advertisement (gone after registration) I use B+W 486 filters on almost all of my lenses and haven't noticed a problem so far. Â I use this as well and along with the WATE code it works perfectly Link to post Share on other sites More sharing options...
