Stabilizing a M8
ashapiro
x
Try the Leica tabletop tripod (14100) and ball head (14110). They make a very versatile combination. You can use the combination to stabilise the camera against your chest or shoulder, a wall or any other suitable object. You can also just use it a tabletop tripod too. I've had one of these combinations for many years. :)
http://en.leica-camera.com/photography/m_system/accessories/tripod_accessories/2200.html
Same as Nicole, but I substitued a Manfrotto 482 ball head...much smaller and lighter than the Leica version.
Jeff
True, but the Leica ball-head is a work of art, beautifully made. Not that I'm knocking Manfrotto, I think their stuff is great.
The table top tripod comes very highly recommended but a couple of weeks back I made an impulse purchase on a Manfrotto monopod to which I've attached my Manfrotto ball head. The monopod is light and it comes with a strap which you wrap around your wrist to create additional stability. All in all a nice, lightweight solution which did not cost me very much to create.
LouisB
I own both...agree the Leica one is beautiful and well made (too bad the older, smaller Leica version is no longer made). So, too, is the Italian design. But, unlike the Leica version, I can put the Leica and Manfrotto combo in a pants pocket, which can have corollary benefits in a singles bar...YMMV.
Jeff
Have a spare $1?
In another related thread (I'm too lazy to search), Lars (I think) reported on a "rifle technique" using his camera strap to stablize the camera. I, too, use a similar but less intricate technique when a tripod isn't available.
Jeff
I'm with Jaap. Properly braced, these are attainable handheld speeds (at least with standard and wider lenses).
Later,
Clyde
By kneeling (to reduce sway), and bracing the elbows to your body, it is possible to shoot the 90 at 1/2 a second.
Thank you all for the information and your suggestions. Shooting hand held at slow speeds is not possible for me because my hands shake too much. I'll see about the table top tripod and/or some form of strap bracing.
Arthur
Just learn to breathe in tune with your right index finger.
Got it in one - of course it also depends on the length of the lens in use - but I've got sharp images up to 35mm at 1/8th. Attached was done with the 28 cron asph. At 100% it's pin sharp. Shanghai earlier this year...
Best...
Arthur
The Leica mini-tripod has been used since time immemorial as a chest brace by Leica photographers. It works best for this purpose using the old short ballhead, or a third-party ballhead, not the current long one.
