LotharZhou Posted August 20, 2009 Share #1 Posted August 20, 2009 Advertisement (gone after registration) Today I rub my finger very gently over my M8 top plate, notice the paint or some very tiny black plastic ring segments went off from the small round digit display glass. Do any of you have found similar issue? Or should I just ignore it, so tiny but I can still notice it. Thanks Link to post Share on other sites More sharing options...
Advertisement Posted August 20, 2009 Posted August 20, 2009 Hi LotharZhou, Take a look here M8 small issues, the tiny black ring on top plate digit display window.. I'm sure you'll find what you were looking for!
Shootist Posted August 20, 2009 Share #2 Posted August 20, 2009 On my chrome M8 that black ring looks like it is on the bottom, underneath, the coverglass covering the shots remaining LCD. I looked at it with a lighted sensor loupe. Could be that coverglass on your M8 was installed upside down and I would think the black ring is where the glue is placed that hold the coverglass to the ring and that whole assembly, glass and ring, into the recess on the top plate. I'd check the glass is not loose. Do you have the ring? If so I'd send the camera in, along with the ring, to have it looked at and if needed fixed. Link to post Share on other sites More sharing options...
M. Valdemar Posted August 20, 2009 Share #3 Posted August 20, 2009 Personally, I'd kill myself. Link to post Share on other sites More sharing options...
LotharZhou Posted August 20, 2009 Author Share #4 Posted August 20, 2009 yes, the black ring is underneath the glass for sure, what I am say is the very thin ring above the glass, looks like paint and the segments went off. The top thin black ring is about 0.2mm wide. you can hardly notice it unless you actually see it in pieces. Thanks! On my chrome M8 that black ring looks like it is on the bottom, underneath, the coverglass covering the shots remaining LCD. I looked at it with a lighted sensor loupe.Could be that coverglass on your M8 was installed upside down and I would think the black ring is where the glue is placed that hold the coverglass to the ring and that whole assembly, glass and ring, into the recess on the top plate. I'd check the glass is not loose. Do you have the ring? If so I'd send the camera in, along with the ring, to have it looked at and if needed fixed. Link to post Share on other sites More sharing options...
Shootist Posted August 20, 2009 Share #5 Posted August 20, 2009 yes, the black ring is underneath the glass for sure, what I am say is the very thin ring above the glass, looks like paint and the segments went off. The top thin black ring is about 0.2mm wide. you can hardly notice it unless you actually see it in pieces. Thanks! Is this on a Black Chrome or Silver Chrome M8 or Silver Chrome or Black Paint M8.2? Need some more specifics. On my original Silver Chrome M8 there is no top black ring around that window and the glass is slightly recessed below the surface of the top plate. Maybe I had one at one time and never noticed it came off. Link to post Share on other sites More sharing options...
Shootist Posted August 20, 2009 Share #6 Posted August 20, 2009 Personally, I'd kill myself. Why don't you go outside and play in your sand box. Link to post Share on other sites More sharing options...
jaapv Posted August 20, 2009 Share #7 Posted August 20, 2009 Advertisement (gone after registration) Why don't you go outside and play in your sand box. Irony-detector out of calibration? Link to post Share on other sites More sharing options...
LotharZhou Posted August 20, 2009 Author Share #8 Posted August 20, 2009 it's a 7 month old Silver Chrome M8and there is a very very thin black ring on the glass as I described. you are right the glass is slight below the top plate, around 0.1-0.2mm. the ring is around this area. Is this on a Black Chrome or Silver Chrome M8 or Silver Chrome or Black Paint M8.2?Need some more specifics. On my original Silver Chrome M8 there is no top black ring around that window and the glass is slightly recessed below the surface of the top plate. Maybe I had one at one time and never noticed it came off. Link to post Share on other sites More sharing options...
Shootist Posted August 20, 2009 Share #9 Posted August 20, 2009 Irony-detector out of calibration? Could be or just a troll. Link to post Share on other sites More sharing options...
Shootist Posted August 20, 2009 Share #10 Posted August 20, 2009 it's a 7 month old Silver Chrome M8and there is a very very thin black ring on the glass as I described. you are right the glass is slight below the top plate, around 0.1-0.2mm. the ring is around this area. After Re-reading your posts you are saying that you had a small black ring on top of the glass that now has broken into segments and one of those segments has come off so you can clearly see it? Is that correct? On mine there is not top black ring of any type. If the glass isn't loose I wouldn't worry about it. I did notice that the edge of the glass seems to be painted or somehow marked with a black substance because I can't see the chrome on the edge of the recess the glass fits into. Could be the person or machine that coats the edge of that glass got some on the top surface and that is what came off. Link to post Share on other sites More sharing options...
M. Valdemar Posted August 20, 2009 Share #11 Posted August 20, 2009 Probably one of those trolls. Link to post Share on other sites More sharing options...
LotharZhou Posted August 20, 2009 Author Share #12 Posted August 20, 2009 correct, it is the edge of glass has that black substance that came off. It's not important as the glass is not loose at all. Just wondering if anyone noticed the same thing, thanks very much for the help! After Re-reading your posts you are saying that you had a small black ring on top of the glass that now has broken into segments and one of those segments has come off so you can clearly see it? Is that correct?On mine there is not top black ring of any type. If the glass isn't loose I wouldn't worry about it. I did notice that the edge of the glass seems to be painted or somehow marked with a black substance because I can't see the chrome on the edge of the recess the glass fits into. Could be the person or machine that coats the edge of that glass got some on the top surface and that is what came off. Link to post Share on other sites More sharing options...
