Vilsonius Posted August 3, 2009 Share #1 Posted August 3, 2009 Advertisement (gone after registration) I am using Capture One 4 to process the DNG files from my new M8.2. When I open the DNG files in Capture One Pro I can see the distinctive excellent sharpness from the M8. But when i export the files as TIFF or JPEG and view them in other programs like Photoshop, Lightroom or simply the Preview app (I am using a Mac) the sharpness is gone. I mean everything else is fine (color, tones, etc) but the exported file lacks the sharpness I can clearly see when i view the DNG in Capture One. I have not checked the Disable Sharpness box in the Output settings, so am I doing something wrong here ? Link to post Share on other sites More sharing options...
Advertisement Posted August 3, 2009 Posted August 3, 2009 Hi Vilsonius, Take a look here Capture One TIFF export sharpness problem. I'm sure you'll find what you were looking for!
Jamie Roberts Posted August 3, 2009 Share #2 Posted August 3, 2009 I am using Capture One 4 to process the DNG files from my new M8.2. When I open the DNG files in Capture One Pro I can see the distinctive excellent sharpness from the M8. But when i export the files as TIFF or JPEG and view them in other programs like Photoshop, Lightroom or simply the Preview app (I am using a Mac) the sharpness is gone. I mean everything else is fine (color, tones, etc) but the exported file lacks the sharpness I can clearly see when i view the DNG in Capture One. I have not checked the Disable Sharpness box in the Output settings, so am I doing something wrong here ? The Preview is always going to look a little bit different from the actual TIFF output, and C1 is, by design, very light on sharpening (you typically only want to sharpen when you print). If you want a sharper TIFF, go to the output tab and sharpen to taste. Remember what you like and save it as a preset, and you're done. Link to post Share on other sites More sharing options...
MV8 Posted September 2, 2009 Share #3 Posted September 2, 2009 Make sure Sharpening is "clicked" off in the process tab, if it's disabled it will preview with your sharpening setting but will not process with them. I agree with Jamie, usually want to sharpen right before you print. Link to post Share on other sites More sharing options...
microview Posted September 3, 2009 Share #4 Posted September 3, 2009 I think the OP is right: if you keep C1 open and convert a DNG to Tiff in CS3 then scale both on screen to the same enlargement, you see how fuzzy the Tiff is compared to the on-screen resolution of the DNG. Colour degradation is also present, slightly. It would be great to get a perfect match. Even so, opening/converting Leica raw files simply in CS3 mostly (not always) gives you an inferior end result. Link to post Share on other sites More sharing options...
dpattinson Posted September 3, 2009 Share #5 Posted September 3, 2009 I don't find this to be the case, but I definitely disable sharpening in C1 and I also pull the sharpening and both noise sliders to zero. I find the noise reduction in CS4 murders fine detail. Link to post Share on other sites More sharing options...
chuckw Posted September 4, 2009 Share #6 Posted September 4, 2009 I am using Capture One 4 to process the DNG files from my new M8.2. When I open the DNG files in Capture One Pro I can see the distinctive excellent sharpness from the M8. But when i export the files as TIFF or JPEG and view them in other programs like Photoshop, Lightroom or simply the Preview app (I am using a Mac) the sharpness is gone. I mean everything else is fine (color, tones, etc) but the exported file lacks the sharpness I can clearly see when i view the DNG in Capture One. I have not checked the Disable Sharpness box in the Output settings, so am I doing something wrong here ? I don't think that you are doing anything wrong; I notice the same thing, sharpness applied in C1 does not seem to carry over to the exported tiff file like the other C1 adjustments. Like others, I leave any serious sharpening to Photoshop. Link to post Share on other sites More sharing options...
