enty Posted July 27, 2009 Share #1 Posted July 27, 2009 Advertisement (gone after registration) having received my E39 filter from Leica (for cron 50), the original lens-cap is a poor fit over the filter - clearly protruding well over the edge of the filter and undoubtedly going to get knocked off and lost. can post a snap if you want, but I'm sure many of you must have seen the similar problem on your own gear. is there a smaller lens cap made specifically for the filters? Link to post Share on other sites More sharing options...
Advertisement Posted July 27, 2009 Posted July 27, 2009 Hi enty, Take a look here lens cap - poor fit with filter. I'm sure you'll find what you were looking for!
jaay Posted July 29, 2009 Share #2 Posted July 29, 2009 the same is true with the filter on the 50 lux, without the filter it sits flush with the extending hood but with the uv/ir filter it protrudes over the filters edges begging to ping off and be lost! a smaller cap the size of the filters would be nice if anyone knows of one. Link to post Share on other sites More sharing options...
sepiareverb Posted July 29, 2009 Share #3 Posted July 29, 2009 I just keep the hood slightly extended to bring it out flush with the cap again. Link to post Share on other sites More sharing options...
jaay Posted July 29, 2009 Share #4 Posted July 29, 2009 i was thinking that a cheap third party one closer to the dimensions of the filter would be good as then i wouldnt care about losing it! try this: http://cgi.ebay.co.uk/39MM-LENS-CAP-SNAP-CAP_W0QQitemZ390071772159QQcmdZViewItemQQptZLens_Accessories?hash=item5ad216e3ff&_trksid=p3286.c0.m14#ht_500wt_1179 im going to buy a cheap no-brand 46mm lens cap from ebay too. Link to post Share on other sites More sharing options...
Shootist Posted July 29, 2009 Share #5 Posted July 29, 2009 I just keep the hood slightly extended to bring it out flush with the cap again. +1 with this. Link to post Share on other sites More sharing options...
danyves Posted July 29, 2009 Share #6 Posted July 29, 2009 Gently press opposite sides of cap to thighten it. Should hold in place. Link to post Share on other sites More sharing options...
luigi bertolotti Posted July 29, 2009 Share #7 Posted July 29, 2009 Advertisement (gone after registration) Gently press opposite sides of cap to thighten it. Should hold in place. Not so easy if you have a fine old Leitz metal cap... they are very solid: I had the same problem with my classic E39 lenses... the right solution is to use a cheap plastic... pity to store in the shelf those fine old caps with velvet internal strip... Link to post Share on other sites More sharing options...
