shutter release cable for M8?
super7668
Does M8 require special shutter release cable? Or just any standard one?
Sorry, I never use this before, have no idea at all. Saw some mentioned only for certain model of Canon, and some for Nikon, just confused. I thought all mechanical one should work...
Thanks.:D
x
The 'jinfinance' release, as well as the 'Leica' one have a decades old standard thread and both will work.
There is nothing special about the 'Leica' release - the seller is just using Nikon and Leica key words to attract more hits to his auction. It is not a 'Leica' release, just a regular cable release made in Germany by any one of many accessory manufacturers (HAMA, ROWI, Prontor etc.).
Best,
Jan
Best,
Jan
My fault, I understand that's not a genuine Leica one.
So, both should work for M8?
Thanks
Just go to your local photo store and buy a standard, older style that was used on cameras from around 1954 until the late 80's or longer, cable release.
No need to order one from china (although the one you buy in your local camera store might be made in china).
........So, both should work for M8?
...."The 'jinfinance' release, as well as the 'Leica' one have a decades old standard thread and both will work"....
....."Any old cable release will do".......
...."Just go to your local photo store and buy a standard, older style that was used on cameras from around 1954 until the late 80's or longer, cable release"......
Let me know if you need more assurances as to the compatibility of your M8 with the cable releases in question. I will have my lawyer prepare a full disclosure statement and we'll have it courriered to you. :D;):p
If you need the cable release for tonight's 'Symphony of Fire' fireworks, it may be a little too late, unfortunately......
Best,
Jan
Best,
Jan
I really have no idea about the cable since I never use one, they all looks similar to me; and seems google can't help. The problem already solved.
Luckily I need the cable for next week's fireworks.
Just about any mechanical cable release, as long as it has the tapered thread, and not the older straight thread.
However...
Give it a check to make sure the action is smooth. Some cable releases are draggy and/or rough. Test a cable by making a single loop for shorter releases, or two complete loops for longer ones and then activating the plunger. With a good cable release you should not notice a significant change in drag.
For a locking release, consider how the locking mechanism works. The disc/collar type always seems to deploy when I don't want it to. And they seem to require (at least for me) more fiddling to get released. I prefer the actual screw locks.
I've had a Linhof release for about 20 years. Wonderfully well made. It is longer than most, but I've found the length to work out well in the field.
I agree that any cable release will work, but the cheapies will feel gritty when you press them. My Hasselblad cable release, however, feels nice and smooth and perfect for the M8.
If you use the M8 on a tripod instead of using a cable you could also consider the 2s autotimer (this also works for B mode) a second very light touch of the shutter release then ends the exposure. This is so light that it should not cause any camera shake.
Kalina, you're a rich girl then... :D It is anexpensive gadget.
In my M8s, I would use only a gold or platinium cable with some precious stones (diamonds would do it) :D
Ah yes, Im waiting for the special editiion white cable release from Leica. I understand it will be a bargain at 2,000 Euros.
I have a genuine Leica cable release, with the white box, that you can have for only €1,000 if you like? :D
I cannot believe you will let a genuine article go at such low price! What will the collectors say?
Does it come with a red dot, btw?
