Cirrus1 Posted July 24, 2009 Share #1 Posted July 24, 2009 Advertisement (gone after registration) I know.... weird sounding title, but I just bought a used Digilux 2 online and it arrived today. It has an odor of stale cigarette smoke. I wiped it down with lens cleaner but it still smells. I am thinking of using rubbing alcohol now but I am worried about damaging anything. It will be heading to Leica for a new sensor and service next week and I'd like to remove as much smell as I can before it goes. Any thoughts or suggestions? Thanks in advance. Regards, John Link to post Share on other sites More sharing options...
Advertisement Posted July 24, 2009 Posted July 24, 2009 Hi Cirrus1, Take a look here Smelly Digilux 2. I'm sure you'll find what you were looking for!
lykaman Posted July 24, 2009 Share #2 Posted July 24, 2009 Pop it in a plastic bag with some POTPOURRI->ideally wrap the PotP" in a sock to eliminate the particles getting into the camera..L Link to post Share on other sites More sharing options...
doubice Posted July 24, 2009 Share #3 Posted July 24, 2009 John, Don't use any alcohol based liquids - may damage the plastic. Soap and water works wonders, of course be careful with how much moisture you use. Dip an old toothbrush into some soapy water, drain a lot of the liquid from the bristles to almost make the brush semi-dry and brush away. Wipe off with a clean cloth. This has worked for me on many cameras that when received, looked as if pulled out of a hungry dog's mouth. Good luck, Jan Link to post Share on other sites More sharing options...
Cirrus1 Posted July 25, 2009 Author Share #4 Posted July 25, 2009 Thanks doubice for the heads up on the alcohol. I took your advise and used a damp spoonge with a little soap and aggressivly wiped down the camera being careful not to let any water squeeze out of the sponge. The smell is 70% gone. Its is now only in the rubberized areas. I'll see if leica can replace them. DL4guy... I am serously considering your suggestion if it comes back smelly, although maybe just a little cologne on it instead : ) Thanks again for the replies. Link to post Share on other sites More sharing options...
pop Posted July 25, 2009 Share #5 Posted July 25, 2009 Store it in a place where the air is constantly renewed, i.e. in a droughty place. Link to post Share on other sites More sharing options...
Guest flatfour Posted July 25, 2009 Share #6 Posted July 25, 2009 To remove smoke smells from anything - car interiors etc. etc. Get a bagful of grass cuttings, the quanitity depending on the volume to be cleared of the smoke odours. Put the camera in a plastic bag of dry, but not dried, grass cuttings. and leave overnight. To clear a room you will need a couple of large grass boxes full. Link to post Share on other sites More sharing options...
rjsplace Posted July 31, 2009 Share #7 Posted July 31, 2009 Advertisement (gone after registration) I would place the camera near a high quality ion ozone air filter it will clear up most smells. See other posts here for replacing the banding to a cool leather or other hide product Link to post Share on other sites More sharing options...
jaapv Posted July 31, 2009 Share #8 Posted July 31, 2009 Cameraleather will recover your Digilux2 with beautiful leather, and it will smell correspondingly - highly recommended. Link to post Share on other sites More sharing options...
