50 Summilux-M on Panasonic G1
dankhong
Folks,
I had a chance to try out the Summilux-M on a Lumix G1 using a Voigtlander adapter.
Set at f5.6, aperture priority mode, I noticed that the shutter speed on the camera was 6, which I interpret as 1/6 sec. Checking the exposure setting with my Voigtlander VC meter revealed an exposre setting of 1/60 sec at f5.6. ISO was 400 on both camera and meter.
Shots taken showed some degree of camera shake consistent with a shutter speed of 1/6 sec.
I wonder why is there such a vast difference in the shutter speed on the camera as compared with that on the external exposure meter?
Dan K.
cleardot.gif Reply
cleardot.gif Forward
The G1 is metering through the lens and the 50mm lens will be providing a much more narrow field of view than the VC meter. You can also set the G1 meter to a spot meter mode which will narrow the field even further.
With the difference in field of view, it's possible the two meters are looking at entirely different brightness levels leading to different readings.
