super7668 Posted June 27, 2009 Share #1 Posted June 27, 2009 Advertisement (gone after registration) I need one for my new CV 15/4.5 M, which filter is better on Ebay? Should all 52mm filters fits this lens? B+W? HOYA? ... Link to post Share on other sites More sharing options...
Advertisement Posted June 27, 2009 Posted June 27, 2009 Hi super7668, Take a look here which 52mm filter for M8?. I'm sure you'll find what you were looking for!
offshore Posted June 28, 2009 Share #2 Posted June 28, 2009 I need one for my new CV 15/4.5 M, which filter is better on Ebay? Should all 52mm filters fits this lens? B+W? HOYA? ... You don't say which filter you want but all 52 mm diameter filters will work. Link to post Share on other sites More sharing options...
ampguy Posted June 28, 2009 Share #3 Posted June 28, 2009 You may get better images without a filter with this lens. Link to post Share on other sites More sharing options...
super7668 Posted June 28, 2009 Author Share #4 Posted June 28, 2009 You may get better images without a filter with this lens. Thanks. But I still need to face the UV/IR problem with this lens; Any better solution available? Link to post Share on other sites More sharing options...
super7668 Posted June 28, 2009 Author Share #5 Posted June 28, 2009 You don't say which filter you want but all 52 mm diameter filters will work. I'm new to RF, however I only found those two brands has UV/IR cut filter for 52mm. Any suggestion? Link to post Share on other sites More sharing options...
divory Posted June 29, 2009 Share #6 Posted June 29, 2009 I would recommend the B+W - Leitz do not make a filter with this thread. I also code it as a WATE at 16mm and am delighted with the results. Welcome to the M8 world! David Link to post Share on other sites More sharing options...
jaapv Posted June 29, 2009 Share #7 Posted June 29, 2009 Advertisement (gone after registration) All major brands; B&W, Heliopan or Hoya work just fine. Link to post Share on other sites More sharing options...
offshore Posted June 29, 2009 Share #8 Posted June 29, 2009 I would recommend the B+W - Leitz do not make a filter with this thread. I also code it as a WATE at 16mm and am delighted with the results. Welcome to the M8 world! David Divory do you have a pic of the back of your lens showing the coding please? Thanks. Link to post Share on other sites More sharing options...
LeicaMSeattle Posted June 29, 2009 Share #9 Posted June 29, 2009 This is the filter: B+W 52mm 486 UV/IR Cut MRC Heliopan UV/IR filters are not quite as good on the M8 as are the Leica and B+W Link to post Share on other sites More sharing options...
