doubice Posted May 19, 2009 Share #1 Posted May 19, 2009 Advertisement (gone after registration) My Digilux 2 came back from Leica New Jersey about a year ago, with a new sensor. I used it a few times but, since the M8 is now my main camera, I put it away and only used it very occasionally. Never with flash....... Today, I tried to take some flash shots and I cannot get the flash to fire or, display in the finder. As I always understood, the flash would come on automatically if ambient light was insufficient - at least that is what I remember from a few years ago when I used it. Now, with exposures in the 1/8s range and the flash head up, I cannot access the flash menu and the flash won't fire. I even took out the manual and read all pages pertaining to flash operation. Is there anything else that some of you Digilux 2 users can recommend? Am I forgetting something? Many thanks, Jan Link to post Share on other sites More sharing options...
Advertisement Posted May 19, 2009 Posted May 19, 2009 Hi doubice, Take a look here Digilux 2 Flash Problem? . I'm sure you'll find what you were looking for!
wda Posted May 19, 2009 Share #2 Posted May 19, 2009 Jan I use bounce flash indoors a lot. Have you pressed the tiny flash button on the top plate right hand side? Link to post Share on other sites More sharing options...
stuny Posted May 19, 2009 Share #3 Posted May 19, 2009 Jan - I had exactly the same problem when I got my replacement D2. The tiny button that David references is the answer. See below. You'll need the flash open, the camera switched on, and if I recall, in the review mode, though maybe the record mode. Link to post Share on other sites More sharing options...
John Thawley Posted May 19, 2009 Share #4 Posted May 19, 2009 The button Stuny is referencing turns the flash On/Off, Automatic, Automatic w/ Red Eye, Manual, Manual w/ Red Eye. The flash does need to be open and the camera in "record" mode in order to access this menu. Link to post Share on other sites More sharing options...
doubice Posted May 19, 2009 Author Share #5 Posted May 19, 2009 Thanks to all for pointing out the obvious and to Stuart for providing idiot-proof instructions..... duhhh..... I remembered there was a separate flash menu but completely forgot how to access it. Best, Jan Link to post Share on other sites More sharing options...
John Thawley Posted May 20, 2009 Share #6 Posted May 20, 2009 Thanks to all for pointing out the obvious and to Stuart for providing idiot-proof instructions..... duhhh..... I remembered there was a separate flash menu but completely forgot how to access it. Best, Jan Ok... now you've got the flash working... you need to get it under control. Try this. http://www.l-camera-forum.com/leica-forum/digital-forum/78541-digilux-2-bounce-me.html Link to post Share on other sites More sharing options...
doubice Posted May 20, 2009 Author Share #7 Posted May 20, 2009 Advertisement (gone after registration) Thanks for the suggestion, John. I have enough trouble getting used to this set-up... Link to post Share on other sites More sharing options...
