Firmware Bug
marknorton
Working with the camera, I've seen the first what I class as a firmware bug. Firmware 1.06.
When you press play and select an image, you see the initial display followed 2 - 3 seconds later by a change to the display which seems to change the position of the image or its scale, it seems to be compressed horizontally. There's a distinct jump. Working with DNG + JPEG Fine, 10Mp.
It looks like there's a quick initial image display followed by a higher resolution one with noise reduction. If you zoom in immediately after displaying the image, you see a heavily pixelated version first which is then replaced by the higher resolution crop after a few seconds.
Looks to me like the higher resolution image is being displayed in a different position or scale from the initial quick display.
I see the same 'shift' but I agree with Karlitos. I assumed that it just the effect of the 'down sampled' higher resolution image loading in place of the quick and dirty low resolution preview (presumably the 320x240 one buried in the DNG).
