aaron.tam Posted April 18, 2009 Share #1 Posted April 18, 2009 Advertisement (gone after registration) These two pictures were taken with my M2. They were taken with different lenses (CV 25/4 and Summicron 40) and were developed at different labs. My question is: just what is that dark stripe at the top? Those dark stripes are also quite obvious on the negatives. I don't know what the problem is, someone please help. Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted April 18, 2009 Posted April 18, 2009 Hi aaron.tam, Take a look here Please help: Weird Negatives. . I'm sure you'll find what you were looking for!
Finnkare Posted April 18, 2009 Share #2 Posted April 18, 2009 Seems like a problem with the shutter. The blinds are not travelling evenly. It's probably in need of a Clean Lubricate Adjust. Unless it has just been done, properly. Link to post Share on other sites More sharing options...
pop Posted April 18, 2009 Share #3 Posted April 18, 2009 Seems like a problem with the shutter. The blinds are not travelling evenly. I don't think so. In the M2 the shutter travels along the long axis of the image. Let's list what we know about the problem - All pictures exhibit what appears to be a dark strip - the strip is clearly delimited and of constant width - the width of the strip is roughly one twentieth the width of the image, i.e. on the order of 1 mm on the negative. - the strip is produced on the bottom side of the camera I can not really tell if the problem lies in a dark strip. I could very well imagine that the remaining nineteen twentieth of the image are brighter on account of some stray light entering the camera. I also seem to observe that there is a gradient running from the bottom of the image (darker) to the top of of the image, up to the darker strip (where the image appears to be brightest). As far as I can see, there is quite some haze across all of the picture. Sending the camera to a workshop seems to be a good idea. Link to post Share on other sites More sharing options...
rob_x2004 Posted April 18, 2009 Share #4 Posted April 18, 2009 On my screen the dark portion at top is correct and close to the exposure at the very bottom of frame, and then you have a double burn fading downwards which is effecting the print. I would jsut send the camera off with prints, negs, and an explanation of the circumstances you made the frames and and let whoever sevices determine where the light leak is. Link to post Share on other sites More sharing options...
Finnkare Posted April 18, 2009 Share #5 Posted April 18, 2009 Bimey, of course the shutter is travelling horizontally in a Leica! You guys are probably right: stray light coming from a leak somewhere, maybe from some straight horizontal slit on the bottom side of the camera. The camera is quite useless until it's patched. I have had some light seals replaced in some swing-open SLRs and it hasn't been very expensive. It takes a little while to scratch the old foam rubbers (or whatever) and precisely cutting the new ones, though, so it's not the fastest job, if not the most tool-demanding. I haven't had light leaking problems with a Leica, though, so I wouldn't know where they normally appear. One guess would be the bottom plate, but is there any foam rubber there? Or can it only be bent in order to leak light? What about the back "door" then? Maybe the bayonet can also leak, but could the leak be straight then? Maybe if it's "filtered" through the shutter. Link to post Share on other sites More sharing options...
tobey bilek Posted April 18, 2009 Share #6 Posted April 18, 2009 There is a light seal around the shutter that needs replacing. It is not a do it yourself. Link to post Share on other sites More sharing options...
