R8 alarm display
jwcane.enw
My R8 viewfinder exhibits "LO" in bright sunlight and aperture priority with aperture set to f/8.
Camera is also displaying in the left side of the viewfinder the exclamation point inside a triangle. Manual indicates that this means "metering range is insufficient".
Question: is there a separate battery for the light meter?
Any ideas appreciated
I had that error just two days ago with my R8/DMR. After I separated all parts of the camera (DMR back, DMR bottom, opened the "film" door and cleaned ALL contacts, the camera acted completely normal again.
I had a 2.8 lens attached and the viewfinder said f/8-f/16 and LO.
But when motor or DMR is attached that is the battery, as far as I know. The battery would normally be in the handgrip which is replaced by the DMR or motor.
