Lens hood stuck "please help"
underground
Possible suggestion--
Use pliers or a wrench, but at one point only. Don't put the wrench around the outside diameter of the hood, but grasp with one jaw inside the hood and the other outside.
If you apply pressure from the outside only, you run a risk of deforming the hood. The area you squeeze becomes narrower, forcing the areas outside the wrench grip to become longer. That means the more pressure you apply to grip the hood, the more it deforms and the more it grips the lens.
Another way to try the same: Press your palm against the front of the hood to gain pressure to rotate it. That's less destructive than using a wrench. Try this before grabbing a tool.
Good luck.
Or, use the same technique, but press against the rubber sole of your shoe.
Best,
Jan
