Received two old Leicas...need help about them!
inspire84
Hi,
I'm new to the forum but joined since I have two old Leica cameras that my grandfather had received after the war, I believe in Germany after the Holocaust. I will try to post pictures of them in the next thread but in the meantime can some one tell me more about them (when they were made, how much they are worth)? Are the lenses interchangable. I also notice that through the viewfinder you can't see the shift of focus, was another part needed for this? Thanks guys!
The serial numbers I have are:
#: 260820
#: 435176
Easy answers: the older, a Leica III of 1937, the newer, a Leica IIIc of 1947 (probably... just after WWII there was a little confusion on numbers... could be even 1946).
Similar, but indeed two very different cameras... the IIIc is worth some more detailed pictures... the "just postwar" items can have slight variations during to the difficult situation of materials amd parts availabilty.
No, i believe its a lens protector...that's how i received it. It just screws off. I will post some sharper pics later tonight, I have to charge my cameras battery. I will even use my micro lens for you guys! Can anyone tell me more about functionality of the camera? Some one told me it might need a seperate peice to view whether or not the picture is in focus or not?
Leica is a Rangefinder camera... you focus this way... a little too long to explain here if you never heard of... give a look to the manual of your Leica IIIc:
Leica IIIC instruction manual, user manual, free PDF camera manuals
il piuo bello sono gli invitati !
la prima sera con Roberto Begnini era da non perdere
Bonolis fa la anche sua parte ma e stupendo il suo complice Luca come canta !
la vai a mettere la tua foto del tuo 73 !
Sabato... quando ho tempo... :o, naturalmente la posto sul tuo thread con i 73... ci sarà un accessorio a sorpresa... ;)
