sooky-m + ltm collapsible summicron
Guest leicaphotos
x
Guest leicaphotos
With the inside bayonet mount of your Summicron in collapsed position.
B.
just doesn't seem to lock in securely --- does it twist or lock in place?
thanks so far
do i need the ltm m adapter mounted? (it currently is not)
I suppose you have a collapsible Summicron (otherwise, same "movements", but done with the UOORF adapter, on which you screw in the fixed Summicron lenshead): the female bayonet receptacles of the SOOKY-M are spring-loaded: you have to position the male bayonets of the lens tube inside the above receptacles, then push a little the lens towards the body and at the same time turn it clockwise until (after 45° about) you feel it locks.
That's all: more difficult to explain than doing: for my experience (I use regularly it with my fixed mount Summicron) is better to mount the lens with the SOOKY-M already mounted on the body: the only hassle is that the SOOKY-M's own helicoid tends to rotate while you make the push/turn movement, so better to keep SOOKY-M's focus knob at longest distance (left, seen from front) when you mount the lens (helicoid is stopped), and inverse - shortest distance - when you dismount the lens (same movement - push and rotate counterclockwise).
Hope to have been of help... try and let us know.
Guest leicaphotos
got it to lock in -- should the focus lever be at infinity and locked or not? I did a test shot or two with it infinity locked === didn't seem to work with the adjustable focus == so, will post as soon as I finish the roll
thanks everybody
thanks everybody
The helicoidal ramp from the lens is out of use
You set the increasing factor you want on the SOOKY M ramp and next you move back and forth the camera to get the subject focused in the RF window.
  • 2 weeks later...
Guest leicaphotos
new batch - color - shot today 2.0,fuji 800:cool:
