petewayne Posted January 25, 2009 Share #1 Posted January 25, 2009 Advertisement (gone after registration) Ok......this is the last for the Kennet and Avon Canal......going to find a new subject Crofton is situated at the highest point of the Kennet and Avon Canal and is critical to the entire water supply for the canal. A reservoir was built next to the canal to supply water after the local spring supply was deemed insufficient and this is used to supply the canal via the Crofton Pumping Station, which maintain two James Watt steam powered Beam Engines, which drew water from the springs and reservoir to feed a feeder channel to ensure there was sufficient head of water at the highest point and managed via the Crofton Locks. Link to post Share on other sites More sharing options...
Advertisement Posted January 25, 2009 Posted January 25, 2009 Hi petewayne, Take a look here Crofton Locks. I'm sure you'll find what you were looking for!
biglouis Posted January 25, 2009 Share #2 Posted January 25, 2009 Peter I must say that your entire series about the canal has been most interesting. You may think it is finshed but I suspect you'll be drawn back to it again. LouisB Link to post Share on other sites More sharing options...
stuny Posted January 25, 2009 Share #3 Posted January 25, 2009 Peter - I agree with Big. This installment, by the way, is my favorite so far. Link to post Share on other sites More sharing options...
