henkie Posted December 19, 2008 Share #1 Posted December 19, 2008 Advertisement (gone after registration) Hello, I finally found a variocontrast module for my focomat V35 in excellent condition. I am repainting my darkroom and can not wet print for about 2 weeks. The documentation says that no exposure corrections are necessary if changing from grade 0 to grade 5 (for Ilford multigrade). Is that really so, because if I dial grade 0 "looks" to give more light then grade 5. Thanks Link to post Share on other sites More sharing options...
Advertisement Posted December 19, 2008 Posted December 19, 2008 Hi henkie, Take a look here Focomat V35 Vario Contrast Question. I'm sure you'll find what you were looking for!
christer Posted December 19, 2008 Share #2 Posted December 19, 2008 I use an RH Design Analyser to determine exposure time and paper grade when enlarging. I have very carefully calibrated it so that it gives similar midtones for all paper grades. This calibration is made in 1/12th f-stop steps and the difference between different paper grades from 0 to 3 is zero, one or two one 1/12th f-stop steps; thus effectively the same exposure for all these grades. I have four different brands of paper calibrated. All require about double exposure time when moving from paper grade 3 to grade 4, and then doubling once more when moving to grade 5. The old (very much missed) Polymax is the paper needing the largest adjustment, 2.5 stops. Link to post Share on other sites More sharing options...
gyoung Posted December 20, 2008 Share #3 Posted December 20, 2008 Hello, I finally found a variocontrast module for my focomat V35 in excellent condition. I am repainting my darkroom and can not wet print for about 2 weeks. The documentation says that no exposure corrections are necessary if changing from grade 0 to grade 5 (for Ilford multigrade). Is that really so, because if I dial grade 0 "looks" to give more light then grade 5. Thanks I seem to remember that Ilford used to claim that for Multigrade, but all depends on what density you are reproducing, speed is measured at a particular density (at least in ISO terms) but negatives don't work like that! It is one of those things which are OK in theory, but dont work in practice, you need to test to fit the density range of the neg to that of the paper to get the print you want. Gerry Link to post Share on other sites More sharing options...
jpattison Posted December 20, 2008 Share #4 Posted December 20, 2008 Hi, In my Ilford Multigrade II (2) book from 1982, it states: Filters 0-3.5 require the same exposure. Filters 4-5 require twice as much exposure. (There are 11 in the set, in half increments) I assume the same filters are used in the V35 module shown in the book. Ilford's M/G III and IV filters may be different, but I don't think Leitz updated the module. Regards, John Link to post Share on other sites More sharing options...
jpattison Posted December 20, 2008 Share #5 Posted December 20, 2008 Take a look at this... Heiland SplitGrade system from RH Designs Things have moved on ! John Link to post Share on other sites More sharing options...
jpattison Posted December 21, 2008 Share #6 Posted December 21, 2008 Hi Henkie. Definitive answer ! In Steve Anchell's excellent "Variable Contrast Printing Manual" from 1997, he states.. "The Leica V35 Variocontrast module is adjusted by two dichroic filters so that the gradation can be set continuously by turning a rotary knob. The exposure time stays constant for the entire contrast range, while the filters can be moved out of the optical path for focusing and exposure with white light" (diffused 75watt quartz-halogen projected through a special illuminating unit). Best wishes, John Link to post Share on other sites More sharing options...
waileong Posted December 25, 2008 Share #7 Posted December 25, 2008 Advertisement (gone after registration) The exposure time definitely changes if you base the exposure time on the highlights, which should be the case. Link to post Share on other sites More sharing options...
henkie Posted December 26, 2008 Author Share #8 Posted December 26, 2008 I have finally tested and worked with the module. Exposure times keep constant. Very easy to work with. I definitely recommend it for V35 users who use multigrade papers. It is hard to find, but I'm glad I kept on looking for one ! Thanks for your replies ! Link to post Share on other sites More sharing options...
