Handholding at low speeds-technique
jaapv
This new shutter has shown vast differences in users' ability to handhold slow shutter speeds, and of course there is individual variation in the steadiness of people's hands, but I have a feeling that not everybody is aware of the right way to hold an M8.
1. Hold out the left hand like you are begging (not hard after just buying Leica gear;))
2. Hold the camera in the palm of your hand and focus with thumb and index finger.
3. Hold the camera firmly with your right hand and put your finger flat on the collar and release button. Relax that finger.
You'll find that just the slightest "rolling"twitch of your finger will release the camera without shake.
The most common mistakes are a waving left elbow and above all!! a crooked index finger that does not rest on the collar around the release button. Don't jab the release!
Note that the use of a soft release will make you hold the camera less stable. It may be comfortable, but for slow shutter speeds remove it.
This, of course, works for me and is not a law for others :D. But it is the traditional rangefinder way, and who am I to argue with tradition ;)?
This is so old, that there is on copyright issue, and it is an SLR, but a Leica :D ( and she uses one finger too many to focus!)
  • Replies 45
  • Created
  • Last Reply
Just my 2 cts: I systematically use the 2 seconds self-timer, at any speed. It avoids having to stress on staying steady, and gives enough time to make shure the horizon is straignt even after pushing on the release.
Max
That is exactly the point;You don't ever push the release, you just twitch your finger. If your horizon tilts, or even you lose the slightest bit of steadiness when you release the shutter, you are jabbing. Of course your trick works well, but isn't one of the features of the M8 a zero shutter delay?
I compared my M8 (and a new one brought by the Leica rep) to an M8.2 and took numerous shots, then pixel peeped them later at home. 2-3 stops more handholding ability with the M8.2 (and no, not with the delay option activated!). I hold the camera correctly and my stance and breathing techniques are those recommended in textbooks and workshops. In particular, when taking a number of shots sequentially (not necessarily in continuous mode, just one upon the other) the M8.2 lack of jolt or kick makes an astounding difference. It is the difference between rapid firing a .22 versus a .380, for those who are familiar with guns.
I just got my M8 back from NJ with an upgraded shutter, and in my small experimentation I can say that the new shutter seems to be helping me with slow shutter speeds. Prior to the upgrade I was able to take a decently sharp photo at 1/15 sec. I can now reduce that to 1/8 sec and can even take an acceptably sharp photo at 1/4 sec. I've tried on several occasions over the last few days.
But yes, technique is much more important than hardware. The self-timer is a good approach as well.
I have my own technique for long exposure portrait shots (for which the raised left elbow is unavoidable); wondering if there are any photos in your arsenal of the "certified" approach, Jaap?
As it happens, in the low-light thread, meant as ISO 2500 illustration, but still, 1/6th. It was a bit windy too ;)
http://www.l-camera-forum.com/leica-forum/leica-m8-forum/70385-very-low-light-stuff-7.html#post752324
...But yes, technique is much more important than hardware. The self-timer is a good approach as well.
Technique is extremely important. Set your camera at 1/4 second and shoot the same image over and over and see how your movement varies. I doubt if the shutter is making much difference, but the way you hold the camera and press the release will. The biggest advance in this has been IS which is something the Leica lacks and needs. With IS and good technique, one can get very sharp results hand held with a 50mm focal length as low as a full second on an SLR. Mirror slap and all. So hardware is important too.
Ok, just to prove consistency.
I shot a consecutive series of five shots at 1/4th handheld with a 35 mm lens. There are minor variations in softness, but all are acceptable:
And, a shot at 1/2 sec. Not one of a series, just a single shot:
And here you have :
YES
and
NO
I would still quibble with your Yes shot, I think it is better to lay your finger over the shutter release, with the tip resting on the speed dial, that way a slight flexing of the finger is enough to fire the shutter and there is little, or no downward pressure on the camera.
At least that is what I am trying at the moment and it seems to work.
Others will doubtless disagree.:)
Cheers
I really like your description of the correct way to hold the M camera. I think that holding the hand with the palm outstretched is a poetic way of understanding what we do, begging that the shot will be worthwhile.
I still practise like mad trying to get my technique up to scratch, I find that I get lazy and the elbow wanders out from the body, this is a very worthwhile thread.
Very interesting thread. I seem to remember that Leica included these recommendations in the little red instruction books. How do you hold the camera in the verticle(portrait) position. Years back we used to drop the shutter release to the bottom as this keeps the elbows in.
Roger
Boy, that R3 silver is a pretty camera!
Jaap--I use a slight modification to your finger position that may also work for others: Instead of placing the finger tip flat on the shutter release, I place my first joint on the release. I fire the camera by simply straightening the finger at that joint. (This works well with the M, less so with other equipment.)
Oops--I see Tom already suggested this while I was working on this post. :o
Although Leica includes a "Here's how" picture in the M8 manual (below), the "Not this way" picture above is very helpful, as is your explanation. In addition, those shots show one of us rare normal left-eyed people! :p
... How do you hold the camera in the verticle(portrait) position. ...
Roger--here's Leica's suggestion from the M8 manual:
