63strat Posted November 11, 2008 Share #1 Â Posted November 11, 2008 Advertisement (gone after registration) I've been trying my old Nikon SB-15 flash with my M8.2, and am getting very good results, particularly because the Nikon can tilt. I just picked up a new SF24D Leica flash because of it's pseudo TTL capability. It does work very well and allows me to work with more open f-stops than the Nikon, but I prefer the look of a bounced flash. I've tried big white diffusers and the like and have read just about every post on the SF24D in this entire forum, but it doesn't look like anyone makes a simple angle bracket to attach to the flash window to angle the light upwards. (I'd prefer not to use the Nikon coil cord.) Anyone with any info on this? Link to post Share on other sites More sharing options...
Advertisement Posted November 11, 2008 Posted November 11, 2008 Hi 63strat, Take a look here Leica SF24 flash. I'm sure you'll find what you were looking for!
elansprint72 Posted November 11, 2008 Share #2 Â Posted November 11, 2008 I've been trying my old Nikon SB-15 flash with my M8.2, and am getting very good results, particularly because the Nikon can tilt. I just picked up a new SF24D Leica flash because of it's pseudo TTL capability. It does work very well and allows me to work with more open f-stops than the Nikon, but I prefer the look of a bounced flash. I've tried big white diffusers and the like and have read just about every post on the SF24D in this entire forum, but it doesn't look like anyone makes a simple angle bracket to attach to the flash window to angle the light upwards. (I'd prefer not to use the Nikon coil cord.) Anyone with any info on this? Â I looked for an angle deflector a couple of years ago but did not come up with anything. Did you get a couple of clip-on diffusers with yours? I have one with a squared pattern and one with a sort of circular fresnel pattern but, as I can't find the manual, I don't know what they are intended for. Wide/tele perhaps, if so, which is which? Â One thing I do know is that it costs a fortune in batteries; I bought some rechargeables but they hardly last any time at all. Link to post Share on other sites More sharing options...
lars_bergquist Posted November 12, 2008 Share #3 Â Posted November 12, 2008 Get a Nikon shoe-to-shoe 'system cable' SC-19 (or the older SC-17). It has all the contact pins in the right places, so it works with all Leica functions on. Just hold the flash unit in your left hand, pointing it in any direction. It is a bit less convenient but more flexible than a tilting head. The power is sufficient for all normal uses, at least at ISO 320. Â A note of warning however: I do not know to what extent Nikon flash functions are compatible with Leica. So I would NOT use the Nikon cable with your Nikon flashgun! Â The old man from the Age of Flash Powder Link to post Share on other sites More sharing options...
Shootist Posted November 12, 2008 Share #4  Posted November 12, 2008 Get a Nikon shoe-to-shoe 'system cable' SC-19 (or the older SC-17). It has all the contact pins in the right places, so it works with all Leica functions on. Just hold the flash unit in your left hand, pointing it in any direction. It is a bit less convenient but more flexible than a tilting head. The power is sufficient for all normal uses, at least at ISO 320. A note of warning however: I do not know to what extent Nikon flash functions are compatible with Leica. So I would NOT use the Nikon cable with your Nikon flashgun!  The old man from the Age of Flash Powder Lars the cable is just a extension of the hot shoe. It adds nothing. Pinout on both ends of the cable are the same and is the same pinout as on Nikon and Leica hot shoes. It's like plugging in a extension cord to a wall outlet, you can move your tool/light farther away for the outlet then you can with just the cord supplied with the tool/light. Connecting a flash to the cable is the same as putting it in the hot shoe. If a flash works in the M8 hot shoe with whatever functions are available it will work the same on the far end of the cable. Link to post Share on other sites More sharing options...
jaapv Posted November 12, 2008 Share #5 Â Posted November 12, 2008 I have been known to stick a white piece of cardboard at 45 degrees under the reflector; works quite well, actually. Link to post Share on other sites More sharing options...
jaapv Posted November 12, 2008 Share #6 Â Posted November 12, 2008 I looked for an angle deflector a couple of years ago but did not come up with anything. Did you get a couple of clip-on diffusers with yours? I have one with a squared pattern and one with a sort of circular fresnel pattern but, as I can't find the manual, I don't know what they are intended for. Wide/tele perhaps, if so, which is which? Â One thing I do know is that it costs a fortune in batteries; I bought some rechargeables but they hardly last any time at all. Â Yes, the fresnel one is for tele and the wafered one for WA. The flash recognizes them and adjusts accordingly. Link to post Share on other sites More sharing options...
lars_bergquist Posted November 12, 2008 Share #7 Â Posted November 12, 2008 Advertisement (gone after registration) Lars the cable is just a extension of the hot shoe. It adds nothing. [ ... ]Connecting a flash to the cable is the same as putting it in the hot shoe. If a flash works in the M8 hot shoe with whatever functions are available it will work the same on the far end of the cable. I think you have misunderstood me. Of course the cable adds nothing. But there may be a risk in putting a Nikon system flash on a Leica camera, ESPECIALLY if all pins connect! Are you certain that you know completely what lurks behind each of them? Â Using a Nikon cable to connect a Leica camera to a Leica flash is of course risk-free. Â The old man from the Age of Flash Powder ... BANG! Link to post Share on other sites More sharing options...
lars_bergquist Posted November 12, 2008 Share #8 Â Posted November 12, 2008 Yes, the fresnel one is for tele and the wafered one for WA. The flash recognizes them and adjusts accordingly. The SF24D comes with a manual. Where's yours? Â The old man from the Age of Printed Manuals Link to post Share on other sites More sharing options...
jaapv Posted November 12, 2008 Share #9 Â Posted November 12, 2008 In my bookcase. Link to post Share on other sites More sharing options...
63strat Posted November 12, 2008 Author Share #10 Â Posted November 12, 2008 Is it possible to use a wireless remote unit, to control the SF24? Â Nikon SU-4 Wireless Remote TTL Flash Controller - NT2571 - 3073 Link to post Share on other sites More sharing options...
elansprint72 Posted November 12, 2008 Share #11 Â Posted November 12, 2008 In my bookcase. Â Could you post a photo of your bookcase; then I'll be able to find mine. Link to post Share on other sites More sharing options...
jaapv Posted November 24, 2008 Share #12 Â Posted November 24, 2008 Could you post a photo of your bookcase; then I'll be able to find mine. Â Good luck!! Â Â Link to post Share on other sites More sharing options...
cocker Posted November 24, 2008 Share #13  Posted November 24, 2008 Could you post a photo of your bookcase; then I'll be able to find mine.  Hi Pete,  If you can't find it on Jaap's bookcase perhaps its on one of mine! :D  I think I do have the manual if you want to borrow it! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/68182-leica-sf24-flash/?do=findComment&comment=726035'>More sharing options...
Red Dot Cameras Posted November 25, 2008 Share #14 Â Posted November 25, 2008 I think you will find, if you move the copy of ACT OF WILL by Barbara Taylor Bradford on the bottom shelf,it has slipped behind....thats where I found mine!!!! Link to post Share on other sites More sharing options...
elansprint72 Posted November 25, 2008 Share #15 Â Posted November 25, 2008 Nope, I tried those places, didn't work. My Leica manuals are between the Esperanto Dictionary and Fowler's Modern English Usage, usually. Is it a small black book? Might help if I knew what I was looking for! Link to post Share on other sites More sharing options...
ger1g0 Posted December 10, 2008 Share #16 Â Posted December 10, 2008 I am also interested to try using my Nikon SB-22, which is a compact flash with a tilt head on my spanking new M7. But I am really afraid of frying the circuits. Would using the flash be fine on the manual setting? Link to post Share on other sites More sharing options...
