RachelR-UK Posted October 2, 2008 Share #1 Posted October 2, 2008 Advertisement (gone after registration) I've just acquired a 24mm Elmarit-R E60 which has the bayonet hood with little wheel which I understand is to control a polarising filter mounted on the lens. I do a have such a filter part number 13376 but it's much too thick to fit between the lens and hood. i presume that there is a slimmer polarising filter that will fit? Rachel Link to post Share on other sites More sharing options...
Advertisement Posted October 2, 2008 Posted October 2, 2008 Hi RachelR-UK, Take a look here Use of polarising filter with lens hood . I'm sure you'll find what you were looking for!
arpey Posted October 3, 2008 Share #2 Posted October 3, 2008 Rachel: Isn't filter #13376 a screw-in filter? I believe the filter designed for use with the 24mm Elmarit is filter #13372 - it's much thinner since it doesn't have threads - it should just snap in to the lens hood. Link to post Share on other sites More sharing options...
JBA Posted October 3, 2008 Share #3 Posted October 3, 2008 Is that a circular polarizer that can be used with the Leicaflexes? Link to post Share on other sites More sharing options...
tobey bilek Posted October 3, 2008 Share #4 Posted October 3, 2008 Leica Ser 8 pola filter. Very scarce. It is a hair bigger than other brands ser 8 and will rotate properly. Other brands will not work. It also works in the shade for 35 4.0 Curtagon and 60 2.8, it is the same shade. 133272 is the part # for ser 8 Leitz pola. Save yourself lots of works and get a 60mm screw in Link to post Share on other sites More sharing options...
RachelR-UK Posted October 3, 2008 Author Share #5 Posted October 3, 2008 Randy, Yes #13376 is a screw in filter. I had a closer look at the hood and it is part #12523 and it has inscribed on it R2.8/24 Sr 8 which confirms your and Tobey's comments. JBA, it is a circular polariser. Tobey, #13376 is very thick. I could use it as it is on the lens but I'd have to use it without a hood as anything on the front of that causes bad vignetting. Thanks for all your comments. Rachel Link to post Share on other sites More sharing options...
